when I create SNMP node it works fine, but when I have an IP listing where one of these IP is without access or turned off for example, it repeats the information it collected from another IP.
I don't know how to put my code here, but value there.
"id": "ddd2b570de4e9841",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": ""
"id": "85e286d49b3e53d6",
"type": "template",
"z": "ddd2b570de4e9841",
"name": "Listagem de Impressoras",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "172.16.17.49\n172.16.17.50\n172.16.17.100\n172.16.17.200",
"output": "str",
"x": 270,
"y": 240,
"a3517001fd1b0593"
"id": "a3517001fd1b0593",
"type": "split",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"arraySpltType": "len",
"stream": false,
"addname": "",
"x": 390,
"y": 180,
"59f97d3aa77baba7"
"id": "6a3f7a7f29bdd465",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payloadType": "date",
"x": 160,
"y": 180,
"85e286d49b3e53d6"
"id": "59f97d3aa77baba7",
"type": "change",
"rules": [
"t": "set",
"p": "host",
"pt": "msg",
"to": "payload",
"tot": "msg"
"t": "set",
"p": "port",
"pt": "msg",
"to": "161",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 560,
"y": 180,
"fde8f473dc2b3cab"
"id": "fde8f473dc2b3cab",
"type": "snmp",
"host": "",
"community": "public",
"version": "1",
"oids": "1.3.6.1.2.1.25.3.2.1.3.1,1.3.6.1.2.1.43.16.5.1.2.1.1\n",
"timeout": 5,
"x": 730,
"y": 180,
"e89a0b42a1c38d80"
"id": "168fbe6d4fe96eb9",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 1170,
"y": 220,
"id": "e89a0b42a1c38d80",
"type": "function",
"func": "if(msg.payload !== false){\nmsg.payload.push( { \"ip\" : msg.host } );\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 860,
"y": 180,
"2c2c8297ce237f2a"
"id": "4cf8c8d5842b4159",
"type": "function",
"func": "\n\nvar aJsonArray = new Array();\n\nfor (var i = 0; i < msg.payload.length; i++)\n{\n var aJson = new Object();\n \n aJson.modelo = msg.payload[i][0];\n aJson.status = msg.payload[i][1];\n aJson.ip = msg.payload[i][2].ip;\n aJsonArray.push(aJson);\n}\n\nvar text = JSON.stringify(aJsonArray);\nvar obj = JSON.parse(text);\nmsg.payload = obj;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 860,
"y": 300,
"168fbe6d4fe96eb9"
"id": "2c2c8297ce237f2a",
"type": "join",
"mode": "custom",
"build": "array",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 850,
"y": 240,
"4cf8c8d5842b4159"
