I decided to try out the Arduino node but I can't get the input one to work.
I loaded standardFirmata onto a Uno.
The output blinking pin 13 is working fine.
Input node just says connecting...
Any ideas?
Node-RED 0.18.5 node.js 8.9.4 Win10
[{"id":"ebd1a15d.04265","type":"debug","z":"e0cc4f82.0d1fa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":710,"y":180,"wires":[]},{"id":"7585a3fe.d774cc","type":"inject","z":"e0cc4f82.0d1fa","name":"0.5s tick","topic":"","payload":"","payloadType":"date","repeat":"2","crontab":"","once":false,"onceDelay":"","x":320,"y":320,"wires":[["314ada7d.29bf66"]]},{"id":"e74ef44d.5ec2f8","type":"arduino out","z":"e0cc4f82.0d1fa","name":"","pin":"13","state":"OUTPUT","arduino":"39e5db16.67d3e4","x":740.5,"y":320,"wires":[]},{"id":"314ada7d.29bf66","type":"function","z":"e0cc4f82.0d1fa","name":"Toggle output on input","func":"\n// If it does exist make it the inverse of what it was or else initialise it to false\n// (context variables persist between calls to the function)\ncontext.level = !context.level || false;\n\n// set the payload to the level and return\nmsg.payload = context.level;\nreturn msg;","outputs":1,"noerr":0,"x":528,"y":320,"wires":[["e74ef44d.5ec2f8"]]},{"id":"49748cdc.7c7f24","type":"arduino in","z":"e0cc4f82.0d1fa","name":"","pin":"8","state":"INPUT","arduino":"159278d6.ee9717","x":470,"y":180,"wires":[["ebd1a15d.04265"]]},{"id":"39e5db16.67d3e4","type":"arduino-board","z":"","device":"COM9"},{"id":"159278d6.ee9717","type":"arduino-board","z":"","device":"COM9"}]
