Try this link...
I think you missed the last digit (i.e. 8) off of the link you posted.
Try this link...
You are right indeed. You have to find the template node named "Slideshow Grid" and do a small change on it.
<style>
#Slide_Slideshow .nr-dashboard-template {
background-image : url(/slideshow/{{payload}});
background-repeat: no-repeat;
background-position: center;
background-size: cover;
</style>
It is hardcoded to work with a tab named "Slide" and group named "Slideshow". Change the first line inside the style tag to fit your TAB_Group. In the very same line use the CSS selector ".nr-dashboard-template" as it is more specific then the one used previously (md-card). I will add this explanation to the flow posted in the Library.
Thanks @Andrei . It did work after changed as you mentioned.
to recap for future:
Changing the below line in the "Slideshow Grid" node in the flow
#Slide_Slideshow md-card {
to
#TAB_GROUP .nr-dashboard-template {
where TAB is the the tab name. And, GROUP is the group name.
This flow based on the @Andrei flow above :
creates a slideshow in the Dashboard with pictures from a local directory in your Raspberry pi. The slideshow is controlled by nod-red dashboard buttons.
See the complete topic in the #share-your-projects area : Dashboard slideshow gallery
Probably best to cut/paste just that last post into the #share-your-projects area
yes i will
Thank you @SuperNinja and @Andrei for good word. There is a minor side effect (not critical). Requiring the name of the TAB and GROUP names within the CSS will create a small limitation. It is limiting the user to write the TAB and GROUP names in English only
Hi @newbie for my part, I do not use images in the background, they are displayed as images that can be resized, arranged, as desired in the "web page". I do not modify the CSS.
For testing , use this classic html code:
<style>
img {
width: 100%;
height: auto;
</style>
<body>
<div >
<img src= "/camAlerte/{{msg.fileName}}" alt="Camera Picture" ><br>
</div>
</body>
Where msg.fileName is the name of the file to display Ex: car.jpg send by the previous node.
Of course , change camAlerte by your folder
Try it out.
I will try. Thanks @SuperNinja
Take a look at the complete project :
@SuperNinja, Thanks again. You are right. It did work very well regardless of the language. I will modify my comments. I encountered two small obstacles (maybe because I use windows environment). I will write them in the project page.
Edit (correction) : @SuperNinja work is independent from interface language.
@SuperNinja Thanks again, regarding the small obstacle (only one
) . It is the path of images. In windows, the path type in DIRECTORY node (fs-op-dir node) should be string as shown in image below to work. Hence, we may benefit from @Andrei work to implement the path directly and not using SET PATH node.
That is it
