(a good deed never goes unpunished)
macOS High Sierra 10.13.6
So this morning I decided to install NR 0.20.0 beta 5 (first time installing 0.20.0) to test a bug I reported back in December marked 'fixed'.
So I user sudo npm install -g --unsafe-perm node-red@next and all hell broke loose. The install fails:
Pauls-mini-3:.node-red Paul$ sudo npm install -g --unsafe-perm node-red@next
Password:
npm WARN tar EISDIR: illegal operation on a directory, open '/tmp/npm-95562-60ca229c/unpack-61325073/examples'
npm WARN tar EISDIR: illegal operation on a directory, open '/tmp/npm-95562-60ca229c/unpack-61325073/src'
npm WARN tar EISDIR: illegal operation on a directory, open '/tmp/npm-95562-60ca229c/unpack-61325073/test'
<...SNIP...>
WARN tar EISDIR: illegal operation on a directory, open '/usr/local/lib/node_modules/.staging/multilang-sentiment-0bf75575/test/unit'
WARN tar EISDIR: illegal operation on a directory, open '/usr/local/lib/node_modules/.staging/multilang-sentiment-0bf75575/utils'
npm ERR! path /usr/local/lib/node_modules/node-red/node_modules/js-yaml/bin/js-yaml.js
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! syscall chmod
npm ERR! enoent ENOENT: no such file or directory, chmod '/usr/local/lib/node_modules/node-red/node_modules/js-yaml/bin/js-yaml.js'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! /Users/Paul/.npm/_logs/2019-02-14T09_23_23_426Z-debug.log
When I go look at /tmp/npm-95562-60ca229c it is empty, so nothing has been unpacked into it. If I look at it's ownership I see it is owned by root/wheel
Pauls-mini-3:tmp Paul$ ls -al
total 0
drwxrwxrwt 10 root wheel 320 Feb 14 05:34 .
drwxr-xr-x 6 root wheel 192 Jun 17 2018 ..
-rw-rw-rw-@ 1 Paul wheel 0 Jan 30 14:37 .keystone_install_lock
drwx------ 3 Paul wheel 96 Jan 29 09:50 .vnc-501
drwx------ 3 tug wheel 96 Jan 30 14:18 com.apple.launchd.EZDEB8O8S4
drwx------ 3 tug wheel 96 Jan 30 14:18 com.apple.launchd.cALJ055QjC
drwx------ 3 Paul wheel 96 Jan 29 09:49 com.apple.launchd.dxkgsJ53tE
drwx------ 3 Paul wheel 96 Jan 29 09:49 com.apple.launchd.zbumuD4jFl
srwxrwxrwx 1 _mysql wheel 0 Jan 29 10:10 mysql.sock
drwxr-xr-x 2 root wheel 64 Feb 14 04:22 npm-95562-60ca229c
Any ideas??
