SOLVED: Reed-Relays with NodeRed and Raspberry Pi / Windsensor
Hi everybody,
I am new here and want to build a weather station for my garden with Node-Red.
But now I have the problem that I want to connect a wind sensor to the Pi and the counting of the reed relays/contacts does not work as I want it to.
With the help of a "timed counter" I wanted to count every second the number of closed/open contacts. Unfortunately I never get "0" out. This means in reverse that I will not get a value when there is no wind.
Does any of you have another idea?
Here is my flow:
        "id": "77f55f1.81340a",
        "type": "rpi-gpio in",
        "z": "8fce6b6d.1acf48",
        "name": "GPIO27",
        "pin": "13",
        "intype": "down",
        "debounce": "25",
        "read": true,
        "x": 260,
        "y": 780,
                "5a1777c.b72f288"
        "id": "5a1777c.b72f288",
        "type": "timed-counter",
        "name": "CountGPIO27",
        "timelimit": "1",
        "timeunit": "1000",
        "withhold": true,
        "fixedtimeout": true,
        "pertopic": false,
        "x": 440,
        "y": 780,
                "1bc4fc7d.bedfe4"
        "id": "1bc4fc7d.bedfe4",
        "type": "function",
        "func": "var msg = { payload:msg.count  };\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 610,
        "y": 780,
                "e2b6c2cd.02269",
                "6e79bb99.739644",
                "85804b86.ea72d8"
        "id": "85804b86.ea72d8",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 970,
        "y": 780,
        "id": "e2b6c2cd.02269",
        "type": "function",
        "name": "mps",
        "func": "msg.payload = ((msg.payload+2)/3);\nmsg.payload = msg.payload.toFixed(1)\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 770,
        "y": 740,
                "37678919.a79dd6",
                "e6d1ca03.efb108"
        "id": "37678919.a79dd6",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 970,
        "y": 740,
        "id": "6e79bb99.739644",
        "type": "function",
        "name": "kmph",
        "func": "msg.payload = (((msg.payload+2)/3)*3.6);\nmsg.payload = msg.payload.toFixed(1)\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 770,
        "y": 820,
                "68aa0e1e.75fc5",
                "51a7a8d7.5a4bd8"
        "id": "68aa0e1e.75fc5",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 970,
        "y": 820,
        "id": "e6d1ca03.efb108",
        "type": "ui_gauge",
        "group": "48b04313.4ea4cc",
        "order": 2,
        "width": 0,
        "height": 0,
        "gtype": "donut",
        "title": "",
        "label": "m/s",
        "format": "{{value}}",
        "min": "0",
        "max": "50",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 970,
        "y": 700,
        "id": "51a7a8d7.5a4bd8",
        "type": "ui_gauge",
        "order": 2,
        "width": 0,
        "height": 0,
        "gtype": "donut",
        "title": "",
        "label": "km/h",
        "min": "0",
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 970,
        "y": 860,
        "id": "48b04313.4ea4cc",
        "type": "ui_group",
        "z": "",
        "name": "Windgeschwindigkeit",
        "tab": "1494dab6.b69d15",
        "order": 3,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "1494dab6.b69d15",
        "type": "ui_tab",
        "z": "",
        "name": "Wetterstation",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Hi there,
problem solved - the node "msg-speed" (Link: https://flows.nodered.org/node/node-red-contrib-msg-speed) solved my problem exactly.
Best regards
