Some nodes of core-nodes are not available
Hello, I hope someone could help me, let me explain, I'm using node red v.1.3.4 on orange pi, after upgrade node red I found this
Captura de Pantalla 2021-05-16 a la(s) 10.57.00
Captura de Pantalla 2021-05-16 a la(s) 10.57.16
I can't use the " change node", could anyone help me, thanks
How did you install Node-RED?
I use the node red script
from this page
https://nodered.org/docs/getting-started/raspberrypi
thanks for your support
We’re there any errors during the install?
Started : Sun May 16 05:41:36 UTC 2021
Running for user oswal at /home/oswal
Found global nodes:   :
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package nodered
Now install nodejs
Using n
   installed : v14.17.0 (with npm 6.14.13)
Versions: node:v14.17.0 npm:6.14.13
npm WARN using --force I sure hope you know what you are doing.
Now install Node-RED
npm WARN deprecated bcrypt@3.0.6: versions < v5.0.0 do not handle NUL in passwords properly
npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated bcrypt@3.0.8: versions < v5.0.0 do not handle NUL in passwords properly
npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
/usr/local/bin/node-red -> /usr/local/lib/node_modules/node-red/red.js
/usr/local/bin/node-red-pi -> /usr/local/lib/node_modules/node-red/bin/node-red-pi
> bcrypt@3.0.6 install /usr/local/lib/node_modules/node-red/node_modules/bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v3.0.6/bcrypt_lib-v3.0.6-node-v83-linux-arm-glibc.tar.gz
node-pre-gyp WARN Pre-built binaries not found for bcrypt@3.0.6 and node@14.17.0 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
  CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
  SOLINK_MODULE(target) Release/obj.target/bcrypt_lib.node
  COPY Release/bcrypt_lib.node
  COPY /usr/local/lib/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node
  TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
> bcrypt@3.0.8 install /usr/local/lib/node_modules/node-red/node_modules/node-red-admin/node_modules/bcrypt
node-pre-gyp WARN Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v3.0.8/bcrypt_lib-v3.0.8-node-v83-linux-arm-glibc.tar.gz
node-pre-gyp WARN Pre-built binaries not found for bcrypt@3.0.8 and node@14.17.0 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/node-red-admin/node_modules/bcrypt/build'
  COPY /usr/local/lib/node_modules/node-red/node_modules/node-red-admin/node_modules/bcrypt/lib/binding/bcrypt_lib.node
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/node-red-admin/node_modules/bcrypt/build'
+ node-red@1.3.4
added 350 packages from 316 contributors in 131.471s
1.3.4
Now create basic package.json for the user and move any global nodes
Now add the shortcut and start/stop/log scripts to the menu
Now add systemd script and configure it for oswal
ln: failed to create symbolic link '/usr/bin/python': File exists
Now add launcher to top bar, add cpu temp example, make sure ping works
Memory : 738M
Finished : Sun May 16 05:41:36 UTC 2021
Started : Sun May 16 21:18:26 UTC 2021
Now install nodejs
Using n
+ node-red@1.3.4
added 350 packages from 316 contributors in 143.935s
1.3.4
Memory : 738M
Finished : Sun May 16 21:18:26 UTC 2021
[edited to add ``` before and after paste]
What OS are you using?
since this looks like an orange pi issue (i.e. it's working fine or the RPI's) I'm not going to be able t help since I don't have a orange Pi. Hopefully someone else will jump in with some ideas.
@dceejay Dave any thoughts about this? He’s using an orange pi.
What else is in the startup log?
Hi. Surprised if there is nothing in the log.Tricky to guess why some would load and some not without any log output.
I just change de os to armbian, and the problem is gone, thank you
