hi all i new node-red developper for my domotic project .... i have some question .... (sorry by advance if what i say is not clear, english isn't my native language).
1- with change node i create some flow env var, i try to use it into url in http request node. example flow.sensorID = 12345 and url in http request is https://192.168.2.2/getvalue?sendorID={{{flow.sensor}}} and the uri sended must be look this https://192.168.2.2/getvalue?sendorID=12345 but don't work ....
2 - i have some node (api call some sensor value from my domotic controller) in parallel to optimize execution time, but the last node (condition salon) need all previous node execution is done before execution. how i can create this dependancy ?
part of my flow
[{"id":"ab1ae36c16c51361","type":"tab","label":"Flux 2","disabled":false,"info":"","env":[]},{"id":"3802d677cf600d39","type":"change","z":"ab1ae36c16c51361","name":"init var flow","rules":[{"t":"set","p":"api_user","pt":"flow","to":"XXXXXXX","tot":"str"},{"t":"set","p":"api_secret","pt":"flow","to":"XXXXXXXXXXX","tot":"str"},{"t":"set","p":"light_salon","pt":"flow","to":"660789","tot":"str"},{"t":"set","p":"bright_salon","pt":"flow","to":"1269446","tot":"str"},{"t":"set","p":"plex_scene_id","pt":"flow","to":"689480","tot":"str"},{"t":"set","p":"last_hc","pt":"flow","to":"804022","tot":"str"},{"t":"set","p":"last_salon","pt":"flow","to":"877998","tot":"str"},{"t":"set","p":"chromecast_id_salon","pt":"flow","to":"XXXXXXXXXXX","tot":"str"},{"t":"set","p":"chromecast_id_hc","pt":"flow","to":"XXXXXXXXXXX","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":340,"wires":[[]]},{"id":"2e5df20e04e0afb0","type":"http in","z":"ab1ae36c16c51361","name":"plex web hook","url":"/plexwebhook","method":"post","upload":true,"swaggerDoc":"","x":180,"y":420,"wires":[["458f73f5960fc083","3802d677cf600d39","73d907570add7515","b939e1a651cb4321"]]},{"id":"458f73f5960fc083","type":"http response","z":"ab1ae36c16c51361","name":"","statusCode":"200","headers":{},"x":220,"y":460,"wires":[]},{"id":"b939e1a651cb4321","type":"http request","z":"ab1ae36c16c51361","name":"get light salon","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.xxxxxxxx.com/get?action=periph.caract&periph_id={{{light_salon}}}&api_user={{{api_user}}}&api_secret={{{api_secret}}}","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":500,"y":460,"wires":[["1d188e9d3646e25b"]]},{"id":"73d907570add7515","type":"http request","z":"ab1ae36c16c51361","name":"get brightness salon","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.xxxxxxxx.com/get?action=periph.caract&periph_id={{{bright_salon}}}&api_user={{{api_user}}}&api_secret={{{api_secret}}}","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":520,"y":380,"wires":[["45b37a4f075fa697"]]},{"id":"45b37a4f075fa697","type":"function","z":"ab1ae36c16c51361","name":"getbrightsalon","func":"flow.set(\"brightsalon\", msg.payload.body.last_value);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":380,"wires":[["e2dcab8b53a5ab0d"]]},{"id":"1d188e9d3646e25b","type":"function","z":"ab1ae36c16c51361","name":"getlightsalon","func":"flow.set(\"lightsalon\", msg.payload.body.last_value_text);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":730,"y":460,"wires":[["e2dcab8b53a5ab0d"]]},{"id":"e2dcab8b53a5ab0d","type":"function","z":"ab1ae36c16c51361","name":"condition_salon","func":"\nvar bright = flow.get('brightsalon')\nvar light = flow.get('lightsalon')\nif ( parseInt(bright)<50 && parseInt(light) >0 ) {\n flow.set(\"salon_test\", 'OK');\n} else {\n flow.set(\"salon_test\", 'NOK');\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1060,"y":440,"wires":[[]]}]
thx by advance for your help. have a good day
