Sometimes something is really funny, really funny
I decided on my development system, that I had so much junk in the npm repo, generated while learning how to write custom nodes for NR, I would clean stuff up. So I removed NR (just case I could), removed npm, removed nodejs, just in case something was hanging around. I then installed NR, the approved way, and saw some thing that really made me laugh, really funny (at least to me)...
Running Node-RED install for user pi at /home/pi on raspbian
This can take 20-30 minutes on the slower Pi versions - please wait.
  Stop Node-RED                       ✔
  Remove old version of Node-RED      ✔
  Remove old version of Node.js       ✔  v0
  Update Node.js LTS                  ✔   Node v12.18.2   Npm 6.14.5
  Clean npm cache                     ✔
  Install Node-RED core               ✔   1.1.2
  Move global nodes to local          -
  Install extra Pi nodes              ✔
  Npm rebuild existing nodes          -
  Add shortcut commands               ✔
  Update systemd script               ✔
Any errors will be logged to   /var/log/nodered-install.log
All done.
  You can now start Node-RED with the command  node-red-start
  or using the icon under   Menu / Programming / Node-RED
  Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started  Wed 22 Jul 2020 01:12:29 PM UTC  -  Finished  Wed 22 Jul 2020 01:14:37 PM UTC
The remove (node.js) version 0 reference just cracked me up!
All I see is a small bug in the install script. :face_with_monocle:
Don't fix it... it is worth the humor value to leave it, IMHO.
Is maybe....like the wallet....end of month
