teamviewer is the best i can do
Then I can not help, I thought most browsers can take screenshots.
Try a very simple test to make sure your MQTT broker is working.
You will need to edit my flow and insert the IP address for YOUR broker.
[{"id":"e6c38e507f61e2a1","type":"mqtt in","z":"8765833d3a37a777","name":"","topic":"test","qos":"2","datatype":"auto-detect","broker":"9bae5ec8.785a4","nl":false,"rap":true,"rh":0,"inputs":0,"x":330,"y":660,"wires":[["cbd5a4c2dae7fc55"]]},{"id":"79afd336daf458c5","type":"mqtt out","z":"8765833d3a37a777","name":"","topic":"test","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"9bae5ec8.785a4","x":510,"y":600,"wires":[]},{"id":"9df5cb7356e9bfec","type":"inject","z":"8765833d3a37a777","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Hello world","payloadType":"str","x":340,"y":600,"wires":[["79afd336daf458c5"]]},{"id":"cbd5a4c2dae7fc55","type":"debug","z":"8765833d3a37a777","name":"Check","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":510,"y":660,"wires":[]},{"id":"9bae5ec8.785a4","type":"mqtt-broker","name":"154 server","broker":"192.168.1.154","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
You should get this result when you click the Inject node.
Now click star icon top left to see debug output and post again.
star icon top left
I think @E1cid was probably referring to the Debug Message button.
essentials videos
These videos will explain the basics to you.
[edit] my mistake it is a beetle/bug by looks of it.
Maybe someone has already said this...
You probably need to use this option in the switch node:
That should ensure that when you press a physical switch, your dashboard switch will change to match the light's status.
