If i repeat the input may times manually (by tapping the node), it plays the sound some times. I made a node to repeatedly send inputs, so if I for instance set this to send the value of 1 in to the node 20times with 0.02sec between them it usually gives me the sound, ut not always.
It would help to know what node you are using to play the sound (full name please 'node-red-contrib-????) What version of the node and what versions of Node-RED and node.js (you can get these from the startup log)
I am using the play-soundfile that's in node red. I have been using node-red-contrib-audio earlier, but its not possible to install this node, getting err! Failed at lame@1.2.4 install script.
