Speaking clock with Rhasspy
Good evening to all.
I am home automation user and I discover node red through rhasspy.
I am also a beginner in java script.
For several weeks I have looking for a proper syntax java script to speech the current time.
In the rhasspy voice assistant my intent is [GetTime] and i’d like to hear the current time when i say 'what time is it ?' ( of course in french).
I copied a code template into a tutorial.
Here my code in a node 'Function' who is working (i hear the voice) well with string value example 18(hh) and 45(mn) or other string value :
msg.payload = "{"speech":{"text":"Il est 18 heures et 45 minutes "},"site_id":"" + msg.payload.site_id + ""}"
I found this code below :
var aujourdhui = new Date();
var heure = aujourdhui.getHours();
var minutes = aujourdhui.getMinutes();
var secondes = aujourdhui.getSeconds();
I guess i have to replace 18 and 45 by a 'msg.payload' value but i have syntax errors.
what is the right syntax to replace string time value (18 and 45) to the current time ?
Can you help me, please ?
Try something like this
msg.payload = {"speech":{"text":"Il est " + heure + " heures et " + minutes + " minutes "},"site_id":  msg.payload.site_id };
Instead of that, you could use the neater:
`Il est ${heure} heures et ${minutes} minutes `
Note the back-ticks instead of quotes.
For this to work I only had to remove the json node after the function node.
It is fine now.
THANK YOU very much. :grinning:
