Is anyone else getting a "no servers defined" error with the speedtest node?
Which node are you using node-red-contrib-speedtest or node-red-contrib-speedtest-updated?
What version of NR?
What device are you running NR on?
Neither of those nodes have been updated in over 2 years….
Hmmm, that issue was opened ("No server found, verify your proxy/network" error · Issue #28 · steffenmllr/node-red-contrib-speedtest · GitHub) in December of 2023 and nothing has been done about it so I would assume the node has been abandoned
I wasn't aware of the updated node... I have the original node installed. So, I'll uninstall it and give the updated a try. Thanks for pointing me to the updated node.
