I am new to Node-Red so I hope that I can explain this in a way that makes sense. I am getting data from a program called Pira CZ that triggers when silence is on our station. It uses HTTP Get to input into Node Red and this is what it picks up.
{"0":"STATION:KXKX,STATUS:SILENT,DATE:2020-10-13,TIME:17-58-08"}
I can change the format if it makes sense. I then need to run it through a function node so that I can split it.
STATION:KDDB,STATUS:SILENT,DATE:2020-10-13,TIME:18-00-13
I then split it at the commas to give me four separate values:
STATION:KDDB
STATUS:SILENT
DATE:2020-10-13
TIME:18-01-53
Now, I want to Split these so that the left is the key and the right is the value. I feel like this could be all done in the function node but I lack that level of programming. I am still learning and no better way then to figure out what hasn't worked but I am stumped at this point. I want to be able to log this information as well as send to the UI. There is also a message that will tell us when the station is back to normal as well.
Aloha!
