I want to split the data stream I receive into different variables. The values are separated by a comma.
Enclosed a copy of the data stream
50,57,51,54,0,1,2,2013,2024,32,40561,0,587,0,0,61536,4000,8675,0,1392,45600,3485,52935
Enclosed the node with which I want to read a PV memory via Modbus TCP
[{"id":"a415dce4.a57f","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"f3d27682.364cb8","type":"modbustcp-read","z":"a415dce4.a57f","name":"PV-Speicher alle Werte","topic":"pv-speicher","dataType":"InputRegister","adr":"1059","quantity":"23","rate":"1","rateUnit":"s","server":"aa8af165.8798e","ieeeType":"off","ieeeBE":true,"x":130,"y":120,"wires":[["a4e2a17d.d81f2"]]},{"id":"a4e2a17d.d81f2","type":"json","z":"a415dce4.a57f","name":"","property":"payload","action":"","pretty":false,"x":130,"y":220,"wires":[["846aa32f.9c4a4"]]},{"id":"846aa32f.9c4a4","type":"change","z":"a415dce4.a57f","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"[","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"]","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":220,"wires":[["826a8ee7.982ef"]]},{"id":"826a8ee7.982ef","type":"debug","z":"a415dce4.a57f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":660,"y":160,"wires":[]},{"id":"aa8af165.8798e","type":"modbustcp-server","name":"PV-Speicher","host":"192.168.178.11","port":"502","unit_id":"1","reconnecttimeout":"60"}]
