Split string based on ;
I have a text file with location data when I use the 'file in' node i get strings with the format "A;B;C"
A,B,C don't have a consistent length. How can i split the string and return the value to
Msg.A
Msg.B
Msg.C
Msg.payload (original payload)
Sample data:
L1S3;52.61563261441822;4.0658098986827715
L1S1;52.44174022895096;6.384215548118491
You can use the CSV node
Demo Flow:
[{"id":"b2dac34a6d1fcd85","type":"template","z":"54efb553244c241f","name":"data","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"L1S3;52.61563261441822;4.0658098986827715\nL1S1;52.44174022895096;6.384215548118491","output":"str","x":300,"y":1200,"wires":[["d76adacd90c1773f"]]},{"id":"df069b0fe53e1771","type":"inject","z":"54efb553244c241f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":1200,"wires":[["b2dac34a6d1fcd85"]]},{"id":"d76adacd90c1773f","type":"csv","z":"54efb553244c241f","name":"","sep":";","hdrin":"","hdrout":"none","multi":"mult","ret":"\\n","temp":"A, B, C","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":420,"y":1200,"wires":[["2694dcd575e2d741"]]},{"id":"2694dcd575e2d741","type":"debug","z":"54efb553244c241f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":590,"y":1200,"wires":[]}]
The csv node is an excellent choice. Another option is,
node-red-contrib-string
This node has options to parse values to array elements. This should be the easiest way to do the most (string operations) without programming. You can also run multiple commands in succession to your input string(s).
To manage keeping your original payload value, you can simply use a "Change" node to shift/copy the payload to another element in your message. You can call it "original_payload" or whatever you like. Then retrieve it by shifting it back to the payload after you manage the results of the split elements.
An other solution and better for getting separate messages is using a split node.
