Hi all,
How can I debug that kind of error which occurs visibly within a Split node ?
split TypeError: Cannot convert undefined or null to object
Thanks in advance
Tot
Hi all,
Thanks in advance
Tot
Hi.
I don't think you need to do what you ask.
I suspect the message going into the split node is a null message, or the part it is going to split isn't there.
On the output of the node before this put a debug node and set it to display all the message properties.
That may help you find the problem.
Hope that helps.
Thanks for leading me to the right direction
That's ok.
I know the feeling all too well.
Good luck.
