I did use the search function, but i need some help.
I have an aqara vibration sensor, then gives svalues.
svalue1: "angleX: 0, angleY: 89, angleZ: 1"
What is want, each value seperate, without the text angelY.
How to do that? Maybe an example?
jbudd
2
How does that data get into Node-red?
Is it an object or a string?
Please use a debug node to capture the value in Node-red and post it here.
In a function node you could use something like:
const input = msg.payload.svalue1
const output = {}
input.split(",").forEach(e=>{
const angle = e.split(":")[0].trim()
const value = e.split(":")[1].trim()
output[angle] = Number(value)
msg.output = output
which produces
the output stays the same.
Also i need the output seperate of each angle.
Your debug node is looking at the payload only (the solution offered bt @bakman2 puts the answer into msg.output)
You could simply rejig the function to overwrite the original property...
msg.payload.svalue1 = Object.fromEntries(input.split(',').map(e => {
const parts = e.split(':').map(f => f.trim())
return [parts[0], Number(parts[1])]
return msg
Thanks, that was the solution!!
