Splitting an array of 7, and setting an topic for each message
Hi
I got an function for splitting an array that contains last 7 days of data ( 0-6), where i want the data for the new day like this:
for (let i = 0; i < msg.payload.length; i++) {
    const el = msg.payload[i];
    const entries = Object.entries(el).map(([key, value]) => ({ topic: key, payload: value }));
    node.send([entries]);
The result is 7 messages, but no way to split them to process only the last message in next step
How do i set an topic number (or other key 1-7) for each message or an function for only grabbing msg.payload[6] in the function?
You could, but it depends how much work you are prepared to do. :wink:
And as you have written your own node to do it, then you just do what would otherwise be done outside the given split node in that node.
Shouldn't be to difficult, but what is the structure of the incoming message, and how do you want the structure of the returned messages?
Just take the split node - and with a second switch node - you filter the last message with msg.part.index = 6
If you only want the last one - why bother iterate over the array ? just send the last one in the first place ???
If you mean how can you request one element by using a topic then you can send the payload through a change node to setmsg.payload[msg.topic] to msg.payload
KisYj94CSK
Not sure exactly what you are after but you could do;
As already suggested
const el = msg.payload[6]
const entry = Object.entries(el).map(([key, value]) => ({ topic: key, payload: value }));
return msg
or
    const entries = Object.entries(el).map(([key, value]) => ({ topic: `${key} index ${i}`, payload: value }));
This would give a topic of "key 1" which can be used to select the required msg; or
    if (i === 6) node.send([entries]);
or add a bit to the msg ({ topic: key, payload: value }) becomes ({ topic: key, payload: value, index: i })
Any of these options would allow easy selection of msg 6
