Dear all,
i was able to set up serial communication between my arduino (Wemos D1) and my RBP that runs node red.
sow i am able to read out the values that are sent by the arduino into my node red.
but i dont know how to split the msg.payload(s) from each other sow i can show the value on my dashboard.
can somebody tell me how to do this?
#include <DHTesp.h>
DHTesp dht;
// DHT Sensor
const int DHTPin = 12;
// S1
const int s1 = 5;
int switch1last = 0;
// S2
const int s2 = 4;
int switch2last = 0;
// S3
const int s3 = 0;
int switch3last = 0;
// Lamp1
const int lamp1 = 16;
// Lamp2
const int lamp2 = 14;
// Lamp3
const int lamp3 = 13;
// Analog output pin dimmer1
const int analogOutPinDimmer1 = 2;
int outputValueDimmer1 = 0; // value output to the PWM (analog out)
// relais Dimmer 1
const int rd1 = 15;
String hum;
String temp;
// Timers auxiliar variables
long now = millis();
long lastMeasure = 0;
void setup() {
pinMode(lamp1, OUTPUT);
pinMode(lamp2, OUTPUT);
pinMode(lamp3, OUTPUT);
pinMode(rd1, OUTPUT);
pinMode(s1, INPUT_PULLUP);
pinMode(s2, INPUT_PULLUP);
pinMode(s3, INPUT_PULLUP);
Serial.begin(115200);
dht.setup(D6, DHTesp::DHT22);
void loop() {
now = millis();
// Publishes new temperature and humidity every 10 seconds
if (now - lastMeasure > 10000) {
lastMeasure = now;
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.getHumidity();
// Read temperature as Celsius (the default)
float t = dht.getTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
// float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
// if (isnan(h) || isnan(t) || isnan(f)) {
// if (isnan(h) || isnan(t)) {
// Serial.println("Failed to read from DHT sensor!");
// return;
// Computes temperature values in Celsius
float hic = dht.computeHeatIndex(t, h, false);
static char temperatureTemp[7];
dtostrf(hic, 6, 2, temperatureTemp);
// Uncomment to compute temperature values in Fahrenheit
// float hif = dht.computeHeatIndex(f, h);
// static char temperatureTemp[7];
// dtostrf(hic, 6, 2, temperatureTemp);
static char humidityTemp[7];
dtostrf(h, 6, 2, humidityTemp);
// Publishes Temperature and Humidity values
//temperatureTemp = t;
//humidityTemp = h;
// client.publish("room/temperature", temperatureTemp);
// client.publish("room/humidity", humidityTemp);
hum = String(h);
temp = String(t);
// Serial.println("Humidity: ");
Serial.println(hum);
// Serial.println(" %\t Temperature: ");
Serial.println(temp);
// Serial.println(" *C ");
// Serial.print(f);
// Serial.print(" *F\t Heat index: ");
// Serial.print(hic);
// Serial.print(hif);
// Serial.println(" *F");
//switch 1
int switch1 = digitalRead(s1);
Serial.println(switch1);
delay (100);
