You would split the array, then assign the name (or mac) to a msg.property (msg.topic) you can then split the object. You can then use two switch nodes to route by msg.topic(name) and msg.parts.key(object key) to the dashboard nodes you wish.
e.g.
[{"id":"b6ad4230c91f7ddf","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"name\":\"pill-1\",\"temp\":20,\"gravity\":60},{\"name\":\"pill-2\",\"temp\":22,\"gravity\":62},{\"name\":\"pill-3\",\"temp\":23,\"gravity\":63}]","payloadType":"json","x":130,"y":2740,"wires":[["719872fe65dd71b6"]]},{"id":"719872fe65dd71b6","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":250,"y":2740,"wires":[["4bdac1700cc016e4"]]},{"id":"4bdac1700cc016e4","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"payload.name","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":2740,"wires":[["236174b293100639"]]},{"id":"236174b293100639","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":170,"y":2840,"wires":[["d478d12436bb33f6"]]},{"id":"d478d12436bb33f6","type":"switch","z":"d1395164b4eec73e","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"pill-1","vt":"str"},{"t":"eq","v":"pill-2","vt":"str"},{"t":"eq","v":"pill-3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":310,"y":2840,"wires":[["ae4caa4e8b30f31a"],["2341b6d24041e7f0"],["cc3caef94484ef38"]]},{"id":"ae4caa4e8b30f31a","type":"switch","z":"d1395164b4eec73e","name":"","property":"parts.key","propertyType":"msg","rules":[{"t":"eq","v":"name","vt":"str"},{"t":"eq","v":"temp","vt":"str"},{"t":"eq","v":"gravity","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":510,"y":2800,"wires":[["910122750895da49"],["91b961eb9b086c1c"],["e34d09a70b2ef782"]]},{"id":"2341b6d24041e7f0","type":"switch","z":"d1395164b4eec73e","name":"","property":"parts.key","propertyType":"msg","rules":[{"t":"eq","v":"name","vt":"str"},{"t":"eq","v":"temp","vt":"str"},{"t":"eq","v":"gravity","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":510,"y":2920,"wires":[["7413f0a978a44f1f"],["5e39f253656b56cf"],["aae1b702a7d1d477"]]},{"id":"cc3caef94484ef38","type":"switch","z":"d1395164b4eec73e","name":"","property":"parts.key","propertyType":"msg","rules":[{"t":"eq","v":"name","vt":"str"},{"t":"eq","v":"temp","vt":"str"},{"t":"eq","v":"gravity","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":510,"y":3040,"wires":[["c4d5dbbf069882cf"],["c77f0f4ddb9e288f"],["81ef4a5cf1cd1492"]]},{"id":"910122750895da49","type":"debug","z":"d1395164b4eec73e","name":"name","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2780,"wires":[]},{"id":"91b961eb9b086c1c","type":"debug","z":"d1395164b4eec73e","name":"temp","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2820,"wires":[]},{"id":"e34d09a70b2ef782","type":"debug","z":"d1395164b4eec73e","name":"gravity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2860,"wires":[]},{"id":"7413f0a978a44f1f","type":"debug","z":"d1395164b4eec73e","name":"name","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2900,"wires":[]},{"id":"5e39f253656b56cf","type":"debug","z":"d1395164b4eec73e","name":"temp","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2940,"wires":[]},{"id":"aae1b702a7d1d477","type":"debug","z":"d1395164b4eec73e","name":"gravity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":2980,"wires":[]},{"id":"c4d5dbbf069882cf","type":"debug","z":"d1395164b4eec73e","name":"name","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":3020,"wires":[]},{"id":"c77f0f4ddb9e288f","type":"debug","z":"d1395164b4eec73e","name":"temp","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":3060,"wires":[]},{"id":"81ef4a5cf1cd1492","type":"debug","z":"d1395164b4eec73e","name":"gravity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":3100,"wires":[]}]
p.s. Please share data in text format not as a picture. It makes it easier for others to help you. preferably in an inject node as people can then just hit the inject and run your data.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
