Hi, im trying to get a chart with 7 lines comming from 7 variables from SQL, if i get only 1 variable all is fine in the chart, but if i want 2 or more variables/lines in my chart its imposible to get, someone knows how to do?
I did it in Change node:
[{ "series": ["DepAvg"], "labels": [""], "data": [[payload.{ "x": ."Fecha", "y": ."ExtAvg" }]] }]
Feed the output into a change node and compare what you see with the requirements from the docs.
sorry Colin, but i dont understand what you want to say
my problem is how can i put more lines "y" in my chart from my SQL data
@MA.ING you could use this solution as a starting point.
Thank you so much Steve, this is exactly what i need, working perfect now
