Hello
I'm trying to display data pulled from an SQL database in a chart, i have a function that works with the array of data and displays the line chart no problem. but now i need to add a second (and possibly third) array of data and i dont know where to start with changing the function node or my object format to get two lines on the chart.
this is the function node i use to display my data (i did not write this, i found it online and it worked for me)
var payload=msg.msg1.payload.data;
var data_out=[];
var a1=[];
for(let i=0;i<payload.length;i++)
var temp1={ "x": (payload[i].Log_Dato_Tid), "y":parseInt( payload[i]["Weld_Imin_Profile_Fronius1"])};
a1.push(temp1)
data_out=[a1];
msg.payload=[{
"series": ["count1","date1"],
"data":data_out,
"labels": ["count1","date1"]
I think i need to change it to somehow use msg.msg2.payload.data the same way it uses msg.msg1.payload.data
this is the object data that i input to this node it holds two seperate arrays each (trimmed down so it fits)
{"socketid":"ejwyffMtaCPRDatUAAAB","_msgid":"53b9d9c2.a543f8","msg1":{"payload":{"data":[{"Log_Dato_Tid":"2021-06-09T15:27:47.760Z","Weld_Imin_Profile_Fronius1":312},{"Log_Dato_Tid":"2021-06-09T06:15:16.426Z","Weld_Imin_Profile_Fronius1":1},{"Log_Dato_Tid":"2021-06-09T06:16:29.430Z","Weld_Imin_Profile_Fronius1":2},{"Log_Dato_Tid":"2021-06-09T06:17:42.230Z","Weld_Imin_Profile_Fronius1":3},{"Log_Dato_Tid":"2021-06-09T06:18:55.330Z","Weld_Imin_Profile_Fronius1":4},{"Log_Dato_Tid":"2021-06-09T06:20:08.230Z","Weld_Imin_Profile_Fronius1":5},{"Log_Dato_Tid":"2021-06-09T06:21:21.133Z","Weld_Imin_Profile_Fronius1":6},{"Log_Dato_Tid":"2021-06-09T06:22:34.133Z","Weld_Imin_Profile_Fronius1":7},{"Log_Dato_Tid":"2021-06-09T06:23:46.733Z","Weld_Imin_Profile_Fronius1":8},{"Log_Dato_Tid":"2021-06-09T06:24:59.733Z","Weld_Imin_Profile_Fronius1":9},{"Log_Dato_Tid":"2021-06-09T06:33:01.240Z","Weld_Imin_Profile_Fronius1":10},{"Log_Dato_Tid":"2021-06-09T06:34:14.340Z","Weld_Imin_Profile_Fronius1":11},{"Log_Dato_Tid":"2021-06-09T06:35:27.440Z","Weld_Imin_Profile_Fronius1":12},{"Log_Dato_Tid":"2021-06-09T06:36:40.240Z","Weld_Imin_Profile_Fronius1":13},{"Log_Dato_Tid":"2021-06-09T06:37:53.343Z","Weld_Imin_Profile_Fronius1":14},{"Log_Dato_Tid":"2021-06-09T06:39:06.143Z","Weld_Imin_Profile_Fronius1":15},{"Log_Dato_Tid":"2021-06-09T06:40:19.043Z","Weld_Imin_Profile_Fronius1":16},{"Log_Dato_Tid":"2021-06-09T06:41:31.743Z","Weld_Imin_Profile_Fronius1":17},{"Log_Dato_Tid":"2021-06-09T06:42:44.646Z","Weld_Imin_Profile_Fronius1":18},{"Log_Dato_Tid":"2021-06-09T06:43:57.746Z","Weld_Imin_Profile_Fronius1":19},{"Log_Dato_Tid":"2021-06-09T06:45:10.446Z","Weld_Imin_Profile_Fronius1":20},{"Log_Dato_Tid":"2021-06-09T06:46:23.346Z","Weld_Imin_Profile_Fronius1":21},{"Log_Dato_Tid":"2021-06-09T06:47:36.346Z","Weld_Imin_Profile_Fronius1":22},{"Log_Dato_Tid":"2021-06-09T06:48:49.146Z","Weld_Imin_Profile_Fronius1":23},{"Log_Dato_Tid":"2021-06-09T06:50:02.250Z","Weld_Imin_Profile_Fronius1":24},{"Log_Dato_Tid":"2021-06-09T06:51:15.150Z","Weld_Imin_Profile_Fronius1":25},{"Log_Dato_Tid":"2021-06-09T06:52:28.050Z","Weld_Imin_Profile_Fronius1":26},{"Log_Dato_Tid":"2021-06-09T06:53:40.950Z","Weld_Imin_Profile_Fronius1":27},{"Log_Dato_Tid":"2021-06-09T06:54:53.853Z","Weld_Imin_Profile_Fronius1":28},{"Log_Dato_Tid":"2021-06-09T07:04:24.056Z","Weld_Imin_Profile_Fronius1":29},{"Log_Dato_Tid":"2021-06-09T07:05:36.256Z","Weld_Imin_Profile_Fronius1":30},{"Log_Dato_Tid":"2021-06-09T07:06:48.260Z","Weld_Imin_Profile_Fronius1":31},{"Log_Dato_Tid":"2021-06-09T07:08:00.160Z","Weld_Imin_Profile_Fronius1":32},{"Log_Dato_Tid":"2021-06-09T07:09:12.160Z","Weld_Imin_Profile_Fronius1":33},{"Log_Dato_Tid":"2021-06-09T07:10:24.060Z","Weld_Imin_Profile_Fronius1":34},{"Log_Dato_Tid":"2021-06-09T07:11:35.763Z","Weld_Imin_Profile_Fronius1":35},{"Log_Dato_Tid":"2021-06-09T07:12:47.663Z","Weld_Imin_Profile_Fronius1":36},{"Log_Dato_Tid":"2021-06-09T07:13:59.463Z","Weld_Imin_Profile_Fronius1":37},{"Log_Dato_Tid":"2021-06-09T07:15:11.263Z","Weld_Imin_Profile_Fronius1":38},{"Log_Dato_Tid":"2021-06-09T07:16:23.366Z","Weld_Imin_Profile_Fronius1":39},{"Log_Dato_Tid":"2021-06-09T07:17:35.166Z","Weld_Imin_Profile_Fronius1":40},{"Log_Dato_Tid":"2021-06-09T07:18:46.766Z","Weld_Imin_Profile_Fronius1":41},{"Log_Dato_Tid":"2021-06-09T07:19:58.566Z","Weld_Imin_Profile_Fronius1":42},{"Log_Dato_Tid":"2021-06-09T07:21:10.366Z","Weld_Imin_Profile_Fronius1":43},{"Log_Dato_Tid":"2021-06-09T07:22:22.266Z","Weld_Imin_Profile_Fronius1":44},{"Log_Dato_Tid":"2021-06-09T07:23:34.470Z","Weld_Imin_Profile_Fronius1":45},{"Log_Dato_Tid":"2021-06-09T07:24:46.070Z","Weld_Imin_Profile_Fronius1":46},{"Log_Dato_Tid":"2021-06-09T07:25:58.170Z","Weld_Imin_Profile_Fronius1":47},{"Log_Dato_Tid":"2021-06-09T07:27:10.473Z","Weld_Imin_Profile_Fronius1":48},{"Log_Dato_Tid":"2021-06-09T07:31:31.473Z","Weld_Imin_Profile_Fronius1":49},{"Log_Dato_Tid":"2021-06-09T07:32:32.273Z","Weld_Imin_Profile_Fronius1":50},{"Log_Dato_Tid":"2021-06-09T07:35:23.676Z","Weld_Imin_Profile_Fronius1":51},{"Log_Dato_Tid":"2021-06-09T07:36:32.476Z","Weld_Imin_Profile_Fronius1":52},{"Log_Dato_Tid":"2021-06-09T07:37:33.076Z","Weld_Imin_Profile_Fronius1":53},{"Log_Dato_Tid":"2021-06-09T07:38:33.576Z","Weld_Imin_Profile_Fronius1":54},{"Log_Dato_Tid":"2021-06-09T07:39:34.080Z","Weld_Imin_Profile_Fronius1":55},{"Log_Dato_Tid":"2021-06-09T07:40:34.680Z","Weld_Imin_Profile_Fronius1":56},{"Log_Dato_Tid":"2021-06-09T07:43:05.580Z","Weld_Imin_Profile_Fronius1":57},{"Log_Dato_Tid":"2021-06-09T07:44:06.383Z","Weld_Imin_Profile_Fronius1":58},{"Log_Dato_Tid":"2021-06-09T07:48:07.483Z","Weld_Imin_Profile_Fronius1":59},{"Log_Dato_Tid":"2021-06-09T07:49:07.983Z","Weld_Imin_Profile_Fronius1":60},{"Log_Dato_Tid":"2021-06-09T07:50:08.586Z","Weld_Imin_Profile_Fronius1":61},{"Log_Dato_Tid":"2021-06-09T07:51:09.186Z","Weld_Imin_Profile_Fronius1":62},{"Log_Dato_Tid":"2021-06-09T07:52:09.686Z","Weld_Imin_Profile_Fronius1":63},{"Log_Dato_Tid":"2021-06-09T07:53:10.486Z","Weld_Imin_Profile_Fronius1":64},{"Log_Dato_Tid":"2021-06-09T07:54:10.986Z","Weld_Imin_Profile_Fronius1":65},{"Log_Dato_Tid":"2021-06-09T07:55:11.886Z","Weld_Imin_Profile_Fronius1":66},{"Log_Dato_Tid":"2021-06-09T07:58:31.390Z","Weld_Imin_Profile_Fronius1":67},{"Log_Dato_Tid":"2021-06-09T07:59:31.990Z","Weld_Imin_Profile_Fronius1":68},{"Log_Dato_Tid":"2021-06-09T08:00:32.590Z","Weld_Imin_Profile_Fronius1":69},{"Log_Dato_Tid":"2021-06-09T08:01:33.293Z","Weld_Imin_Profile_Fronius1":70},{"Log_Dato_Tid":"2021-06-09T08:02:33.993Z","Weld_Imin_Profile_Fronius1":71},{"Log_Dato_Tid":"2021-06-09T08:03:34.493Z","Weld_Imin_Profile_Fronius1":72},{"Log_Dato_Tid":"2021-06-09T08:04:35.493Z","Weld_Imin_Profile_Fronius1":73},{"Log_Dato_Tid":"2021-06-09T08:05:36.293Z","Weld_Imin_Profile_Fronius1":74},{"Log_Dato_Tid":"2021-06-09T08:06:36.796Z","Weld_Imin_Profile_Fronius1":75},{"Log_Dato_Tid":"2021-06-09T08:07:37.396Z","Weld_Imin_Profile_Fronius1":76},{"Log_Dato_Tid":"2021-06-09T08:08:37.896Z","Weld_Imin_Profile_Fronius1":77},{"Log_Dato_Tid":"2021-06-09T08:09:38.496Z","Weld_Imin_Profile_Fronius1":78},{"Log_Dato_Tid":"2021-06-09T08:10:38.996Z","Weld_Imin_Profile_Fronius1":79},{"Log_Dato_Tid":"2021-06-09T08:18:16.603Z","Weld_Imin_Profile_Fronius1":80},{"Log_Dato_Tid":"2021-06-09T08:19:17.503Z","Weld_Imin_Profile_Fronius1":81},,"topic":"06-09-2021"},"msg2":{"payload":{"data":[{"Log_Dato_Tid":"2021-06-08T06:13:23.763Z","Weld_Imin_Profile_Fronius1":1},{"Log_Dato_Tid":"2021-06-08T06:14:38.163Z","Weld_Imin_Profile_Fronius1":2},{"Log_Dato_Tid":"2021-06-08T06:15:53.263Z","Weld_Imin_Profile_Fronius1":3},{"Log_Dato_Tid":"2021-06-08T06:17:08.066Z","Weld_Imin_Profile_Fronius1":4},{"Log_Dato_Tid":"2021-06-08T06:18:22.666Z","Weld_Imin_Profile_Fronius1":5},{"Log_Dato_Tid":"2021-06-08T06:19:37.266Z","Weld_Imin_Profile_Fronius1":6},{"Log_Dato_Tid":"2021-06-08T06:26:02.270Z","Weld_Imin_Profile_Fronius1":7},{"Log_Dato_Tid":"2021-06-08T06:27:16.873Z","Weld_Imin_Profile_Fronius1":8},{"Log_Dato_Tid":"2021-06-08T06:46:27.683Z","Weld_Imin_Profile_Fronius1":9},{"Log_Dato_Tid":"2021-06-08T06:47:42.983Z","Weld_Imin_Profile_Fronius1":10},{"Log_Dato_Tid":"2021-06-08T06:48:58.283Z","Weld_Imin_Profile_Fronius1":11},{"Log_Dato_Tid":"2021-06-08T06:50:13.886Z","Weld_Imin_Profile_Fronius1":12},{"Log_Dato_Tid":"2021-06-08T06:51:29.586Z","Weld_Imin_Profile_Fronius1":13},{"Log_Dato_Tid":"2021-06-08T06:52:45.286Z","Weld_Imin_Profile_Fronius1":14},{"Log_Dato_Tid":"2021-06-08T06:55:31.186Z","Weld_Imin_Profile_Fronius1":15},{"Log_Dato_Tid":"2021-06-08T06:56:46.590Z","Weld_Imin_Profile_Fronius1":16},{"Log_Dato_Tid":"2021-06-08T06:58:02.190Z","Weld_Imin_Profile_Fronius1":17},"topic":"06-08-2021"}}
