Ui-Chart Dashboard V2 - Multi-line line chart from SQL data
Hello everyone, I'm looking for your help as I'm new to this. I'm migrating a working project from Dashboard v1 to v2 and am having issues with the display format on line graphs. I need to display multiple temperatures on the graph, referring to the same timeline. The values ​​are read from a SQL server. The array string I get from the server is as follows:
In this case, the temperatures in the array provided by SQL are 2, but in other cases, I get up to 8 temperatures to display. Can you give me some advice on how to format the array for display? For now, I can display one temperature at a time.
With dashboard v1 the graphs looked like this:
Thank you for your help.
I have not done this, but I think the key sentence in the documentation is:
If you want a single piece of data to plot multiple lines, you can set the Series property to JSON , and then provide an array of keys (e.g. ["key1", "key2"] ), which will plot a data point for each key provided, from a single data point.
If you can't get that to work then please provide some sample data so that I can try myself. Use a query that only gives a few points and then see the canned text I will paste below to show you how to copy the array from from the debug pane and paste it here.
In the chart node make sure that the X Axis Limit time that you enter is large enough that your data will lie within that time (measured from the current time).
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
Looking at the picture of your data it seems your chart settings should resemble this
Are you generating the SQL dynamically in response to the user's choice of temperatures to show on the chart?
Thanks for the advice. The solution proposed by jbudd worked for me. I just want to be able to display a name for the various curves that is different from the array name provided by the SQL array. Is this possible? Should I just introduce a function block where I fetch the incoming array from the SQL and rewrite it on output with the modified variable names?
To answer (jbudd) this question, the data is taken from SQL using a fixed query. The only thing left to the user's discretion is to choose whether to display the last hour or the last 24 hours (for a more general view of the graph).
Why not just rewite the SQL to get the names you want to display
Select data_ora, temperatura_zona1 T1, temperatura_zona2 T2 from .........
Ok, I tried modifying the SQL query!
SELECT data_ora,temperatura_zona_1 "T1",temperatura_zona_2 "T2" FROM forno_4 WHERE data_ora >= {{payload}}
Now the output array looks like this:
I didn't think it was possible, perfect! Thanks so much!
Use SQL 'select foo as Temp01, bar as Temp02 ...'
Oh, should have read to the end before i posted!
Tiny phone screen.
AS is optional but i think it makes it clearer you are defining an alias.
