Im trying to select a calculation out of my database.
[{"id":"8db08aab.865c88","type":"mysql","z":"1f216cc0.281a93","mydb":"23c1ad96.82d712","name":"","x":550,"y":1400,"wires":[["8f679bb2.aa3e18"]]},{"id":"34d9ace1.488fa4","type":"function","z":"1f216cc0.281a93","name":"Select statement","func":"msg.topic = \"select concat(round(sum(case when data_soort='AAN' then data_waarde else null end)*100.0/sum(case when data_soort in ('AAN','UIT') then data_waarde else null end),2)) from IOT_DATA\";\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":1400,"wires":[["8db08aab.865c88"]]},{"id":"a47787ef.dd4958","type":"ui_gauge","z":"1f216cc0.281a93","name":"","group":"ef52ec43.10754","order":9,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":970,"y":1380,"wires":[]},{"id":"4f278390.0987fc","type":"debug","z":"1f216cc0.281a93","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1010,"y":1440,"wires":[]},{"id":"d9c0977f.85dd48","type":"inject","z":"1f216cc0.281a93","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":100,"y":1400,"wires":[["34d9ace1.488fa4"]]},{"id":"8f679bb2.aa3e18","type":"function","z":"1f216cc0.281a93","name":"Select output","func":"if (msg.payload >0){\nreturn msg.topic;\n}\nreturn msg;","outputs":1,"noerr":0,"x":730,"y":1400,"wires":[["a47787ef.dd4958","4f278390.0987fc"]]},{"id":"23c1ad96.82d712","type":"MySQLdatabase","z":"","host":"127.0.0.1","port":"3306","db":"VEKO_IOT","tz":""},{"id":"ef52ec43.10754","type":"ui_group","z":"","name":"Pers 77","tab":"6b96da3f.ce1c04","order":1,"disp":true,"width":"24","collapse":false},{"id":"6b96da3f.ce1c04","type":"ui_tab","z":"","name":"Machine data","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
But it returns the full name with value. How can i get just the value?
