According to chatGPT it is possible to compile and turn an Node-Red flow to run stand alone without having Node-red installed.
So far it did not work for me.
Anyone with positive experiences on making a flow runing standing alone without Node-Red?
Just passing by (I have family around)
But…
See my project here (follow the guide to the letter)
It currently only works for Node 18 (I haven’t updated pkg yet - that supports > 18
And one by @dceejay
Great. I will try.
Dear Marcus,
I tried the GitHub - marcus-j-davies/Node-RED-SFE: A Single File Executable framework for Node-RED but had several problems.
On the last stage of the process "npm run-script package" I could not make it work, several missing files.
I had problems before that stage of the process but was able to sort them out.
Any additional clue?
By the way, I installed a fresh Raspberry Pi OS on my Pi 4 and updated it.
And also loaded a fresh Node-Red on it, Loaded my Flow and its modules before starting.
OK - looks like some upstream things have changed.
I dont have time to look at this (Sorry)
Try the solution by @dceejay - Im not sure how compatible it is with Node RED 4 - But based on what I know, it may not actually be relevant?
