Start/ Stop thermostat
Sounds good to me.
You understand how those examples are to be used/tested?
BTW, they are NOT perfect and will need some tweaking to be exactly what you want.
Okay I think I have an understanding of its function
Only because of my OCD, this is a better set of how to do what you want.
[{"id":"b444a0fc38e450fe","type":"inject","z":"7e987ddf260bdf0d","name":"Stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"stop","payloadType":"str","x":260,"y":3340,"wires":[["46e0098845a5e7ec","f8176d2aa65d65d0"]]},{"id":"4f64ae6f5335f34a","type":"inject","z":"7e987ddf260bdf0d","name":"Go","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"go","payloadType":"str","x":260,"y":3380,"wires":[["46e0098845a5e7ec"]]},{"id":"eda8ff856eaa0a27","type":"debug","z":"7e987ddf260bdf0d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":580,"y":3440,"wires":[]},{"id":"2c1ace6b519af552","type":"inject","z":"7e987ddf260bdf0d","name":"existing stuff","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":270,"y":3440,"wires":[["46e0098845a5e7ec"]]},{"id":"46e0098845a5e7ec","type":"gate","z":"7e987ddf260bdf0d","name":"","controlTopic":"control","defaultState":"open","openCmd":"go","closeCmd":"stop","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":420,"y":3440,"wires":[["eda8ff856eaa0a27"]]},{"id":"4cd39153ce4d99c7","type":"inject","z":"7e987ddf260bdf0d","name":"Stop","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"stop","payloadType":"str","x":250,"y":3580,"wires":[["7a30fcaa82d1f41e","d0cf91e6cd3c49a6"]]},{"id":"757a190398377eaa","type":"inject","z":"7e987ddf260bdf0d","name":"Go","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"go","payloadType":"str","x":250,"y":3620,"wires":[["7a30fcaa82d1f41e"]]},{"id":"d24650868b66acef","type":"debug","z":"7e987ddf260bdf0d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":3700,"wires":[]},{"id":"d0c59526418f856f","type":"inject","z":"7e987ddf260bdf0d","name":"existing stuff","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":260,"y":3700,"wires":[["e055f65538399ecb"]]},{"id":"7a30fcaa82d1f41e","type":"change","z":"7e987ddf260bdf0d","name":"Set context","rules":[{"t":"set","p":"state","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":3600,"wires":[[]]},{"id":"e055f65538399ecb","type":"switch","z":"7e987ddf260bdf0d","name":"","property":"state","propertyType":"flow","rules":[{"t":"eq","v":"go","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":3700,"wires":[["d24650868b66acef"]]},{"id":"f8176d2aa65d65d0","type":"change","z":"7e987ddf260bdf0d","name":"Turn off heater","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":3340,"wires":[["eda8ff856eaa0a27"]]},{"id":"d0cf91e6cd3c49a6","type":"change","z":"7e987ddf260bdf0d","name":"Turn off heater","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":3560,"wires":[["d24650868b66acef"]]}]
Pretty much the same as before but for the extra change node included in each example to do what it says. :wink:
Good to hear.
Oh, I'm not sure you are really done with this.
What you have now is control of the thermostat but it is on the edit screen.
Node-Red offers a GUI screen/interface and you can have a nicer looking GUI if you want.
The dashboard?
I have the GUI setup already.
Ok.
The dashboard is the GUI.
