Hi, I want to change the start up path of settings file C:\Users\x6294075\ to the path E:\npm
thanks, Lucas
you can set the userDir or settings file using the command line options as per the docs: Running Node-RED locally : Node-RED
e.g
node-red -u e:/node-red
or
node-red -s e:/node-red/settings.js
Hi Steve I need to execute the .ps1 file and that path always be the E:\npm\settings.js .
The way you say I need to type it every time i start up the node-red.
Not if you create your own batch or PS file.
Are you running node-red as a service? or always manually starting it?
Or use PM2 to manage Node-RED. ![]()
