State value to set for "s7.1.DBs.DB1._2_0" has to be type "boolean" but received type "string"
Hi everyone,
I’m sending an initialization from Node-RED to ioBroker for a Siemens LOGO. The initialization is sent, but I keep getting this error:
In my Node-RED function I map the incoming command ("auto", "off", "on") to the corresponding S7 state and then force the payload to a boolean:
if (msg.payload == "auto") {
  msg.topic = "s7.1.DBs.DB1._2_1";
if (msg.payload == "off") {
  msg.topic = "s7.1.DBs.DB1._2_0";
if (msg.payload == "on") {
  msg.topic = "s7.1.DBs.DB1._2_2";
msg.payload = true;
My debug output (from Node-RED) shows something like this, which looks like a boolean to me:
object
topic: "s7.1.DBs.DB1._2_0"
payload: true
acknowledged: true
timestamp: 1767583290889
lastchange: 1767583290889
_msgid: "70db13186a9f010f"
So I assume I’m sending a boolean, but ioBroker still claims it received a string.
Is there anything I should improve in the function to ensure the value is always treated as a boolean?
Thanks a lot!
Exactly which node are you sending that value to? Check in manage palette for the node package name.
I’m sending and receiving data using node-red-contrib-iobroker 1.2.0.
In the meantime I changed the datapoint type in ioBroker and Node Red from boolean to string, and now I no longer get any error entries in the log. Because of that, I don’t think this is a pure Node-RED issue — it seems more likely that the ioBroker adapter handles this differently (maybe a type conversion or feedback/ack behavior).
I’m going to try to discuss this with one of the adapter’s architects/developers.
What I still don’t understand: why should I use a string (or even the length of a string) for a purely digital signal where only true or false makes sense?
