Hi All,
Status node is generating disconnect event when the server node is connected to tcp server.
Is this a bug in Nodered?
{"fill":"green","shape":"dot","text":"common.status.disconnected"}
Regards,
Shershah
Hi All,
Regards,
Shershah
Hi @shershah
Sorry, you need to tell us what Nodes you are using.
example: what is a server node
is this a node you have installed?
I am connected to TCP serer using "tcp request" type node. I have static node configured which generates an even when tcp server is connected or disconnected. When TCP server is connected , I am getting "common.status.disconnected" value while it must be "common.status.connected".
{"fill":"green","shape":"dot","text":"common.status.disconnected","source":{"id":"126ac01ac9f7971e","type":"tcp request","name":"tcpServer"}}
Can you share your flow?
Checking the source the disconnected status is only triggered when the connection is closed/ended
is your TCP server disconnecting the client (Node RED)?
Can you also let us know your Node & Node RED Version?
Thanks for your immediate reply. I found the issue. I was using assignment operator in function node instead of comparison operator.
Thanks & Regards,
Shershah
Something did come from this.
I'm seeing a lot of i18n placeholders common.status.***** without the use of RED._()
Would explain the status common.status.disconnected instead of disconnected
node-red/packages/node_modules/@node-red/nodes/core/network/31-tcpin.js at master · node-red/node-red (github.com)
The place holders are valid
node-red/packages/node_modules/@node-red/nodes/locales/en-US/messages.json at master · node-red/node-red (github.com)
Just 1 example
