Stopping the Flow
HI .. I am absolutely RAW and new to NODE-RED programming.
I created a Flashing LED program as Flow1 with half second ON and half second OFF that works fine, next I created Alternately flashing two LEDs at 1 second rate as program-Flow2. But when I run Flow2, ..LED2 correctly flashes as per Flow2 rate while LED1 still continues to follow old program Flow1 rate...I do not know an easy way to stop LED1 following Flow1. I would like to know how best I can flush away all previously running programs and how to run only the lastly "Deployed" program..Please help
How are you triggering the first LED? Providing your flow would help.
In order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
If your first flow has an inject node every second/half second, remove the wire coming from it and deploy.
Or you can disable the flow by double clicking on the tab name. Click "enabled" at the bottom and deploy.
Many thanks for the reply.
Yes..I am using INJECT node to start every Flow.
I will improve my post writing in future, and will try disconnecting INJECT, or try "enable".
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Many thanks for your suggestions.
Will definitely watch them.
