"id": "70e51d08eb1bde9c",
"type": "change",
"z": "7b83b20cb732bf2a",
"name": "set memory",
"rules": [
"t": "set",
"p": "#:(file)::modes",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 730,
"y": 320,
"caa5f4b99f7da5b6"
"id": "986f8041a31d81fc",
"type": "change",
"name": "Get memory",
"rules": [
"t": "set",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 550,
"y": 560,
"53eb89dedc94539c"
"id": "fc634b1dea3eb4dc",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "pay",
"op2type": "pay",
"duration": "10",
"extend": false,
"overrideDelay": false,
"units": "s",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 370,
"y": 620,
"986f8041a31d81fc"
"id": "b9f48f5eddd75d47",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "payload",
"payloadType": "msg",
"x": 150,
"y": 620,
"fc634b1dea3eb4dc"
"id": "9db7201c3ddbf7d8",
"type": "server-state-changed",
"name": "Ferie",
"server": "12135e641a9670e0",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "input_boolean.vacation_mode",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 1,
"output_only_on_state_change": true,
"for": "0",
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 230,
"y": 460,
"a6cf3de1910234de"
"id": "c8c1a272d6f63707",
"name": "Borte",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "input_boolean.away_mode",
"haltifstate": "",
"outputs": 1,
"for": "0",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 230,
"y": 240,
"a6cf3de1910234de"
"id": "f9566101d6146066",
"name": "Natt",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "input_boolean.night_mode",
"haltifstate": "",
"outputs": 1,
"for": "0",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 220,
"y": 300,
"a6cf3de1910234de"
"id": "2b6a38ba0191afab",
"name": "Hjemme",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "input_boolean.home_mode",
"haltifstate": "",
"outputs": 1,
"for": "0",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 230,
"y": 360,
"a6cf3de1910234de"
"id": "a6cf3de1910234de",
"type": "switch",
"name": "State Check",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 410,
"y": 300,
"1183ca5e08707323"
"id": "1183ca5e08707323",
"type": "change",
"name": "Extract Entity and Value",
"rules": [
"t": "set",
"p": "entity",
"pt": "msg",
"to": "entityid",
"tot": "msg"
"t": "set",
"p": "value",
"pt": "msg",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 510,
"y": 400,
"70e51d08eb1bde9c"
"id": "98e3445687de0b5f",
"type": "switch",
"name": "Check Entity",
"property": "entity",
"rules": [
"t": "eq",
"v": "input_boolean.away_mode",
"vt": "str"
"t": "eq",
"v": "input_boolean.night_mode",
"vt": "str"
"t": "eq",
"v": "input_boolean.home_mode",
"vt": "str"
"t": "eq",
"v": "input_boolean.vacation_mode",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 4,
"x": 810,
"y": 640,
"481a057009317e50",
"2bc5aaafd00484a9"
"7a65a472e7383f1c",
"9c6e25d2459a7360"
"a51f3f1380d4560f",
"de95f458c34df77c"
"6937a4c2d666c11a",
"bae87d872ef89b9e"
"id": "481a057009317e50",
"type": "api-call-service",
"name": "Activate Away Mode",
"version": 5,
"debugenabled": false,
"service": "turn_on",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"output_location": "",
"output_location_type": "none",
"service_domain": "script",
"mergecontext": "",
"x": 1120,
"y": 540,
"id": "7a65a472e7383f1c",
"name": "Activate Night Mode",
"version": 5,
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"mergecontext": "",
"x": 1120,
"y": 580,
"id": "a51f3f1380d4560f",
"name": "Activate Home Mode",
"version": 5,
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"mergecontext": "",
"x": 1120,
"y": 620,
"id": "6937a4c2d666c11a",
"name": "Activate vacation mode",
"version": 5,
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"mergecontext": "",
"x": 1130,
"y": 660,
"id": "2bc5aaafd00484a9",
"type": "debug",
"name": "Borte",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1070,
"y": 700,
"id": "9c6e25d2459a7360",
"type": "debug",
"name": "Natt",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1070,
"y": 740,
"id": "de95f458c34df77c",
"type": "debug",
"name": "Hjemme",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1080,
"y": 780,
"id": "bae87d872ef89b9e",
"type": "debug",
"name": "Ferie",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1070,
"y": 820,
"id": "53eb89dedc94539c",
"type": "debug",
"name": "debug 5",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 780,
"y": 520,
"id": "caa5f4b99f7da5b6",
"type": "debug",
"name": "debug 6",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 940,
"y": 300,
"id": "12135e641a9670e0",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
So I am working on this flow to set a mode in home assistant when Home assistant and node red starts up. Since it must only happen at startup if power has been gone I need to store the value and collect it when node red starts up. Here is what I am currently at.
