hello everyone, I have a problem I have to store files with the name that is entered in a textbox, and I succeeded the only problem I have is that all the msg.payload is saved inside the file when in actually I need it to be empty
let a = "/path/to/file/";
msg.file = a + msg.payload.file;
msg.payload = "";
Then in the file node use msg.file, and uncheck add a newline to each payload.
Perfect works very well thanks.
another question if i can how do i make the variable
global "msg.file" so that it can also be used in another flow or even on blocks that are not directly connected to each other
You can global.set in the function before returning message.
This is explained in docs
https://nodered.org/docs/user-guide/context
https://nodered.org/docs/user-guide/writing-functions#storing-data
Or you can use a change node to set global.file to msg.file
