Hi all,
I have an IP network cam which should send me the video material to a Raspberry Pi running Node-RED. I want to use Node-RED to store the video in a ring buffer that only contains the last 5 minutes. If I now press a button, the contents of the ring buffer are to be written to another memory and played back on the dashboard.
The ring buffer continues to record.
Do you have any idea if the implementation with Node-RED is so possible?
And do you have any tips for this?
Thank´s
Georg
