Storing Credentials
First time making my own nodes.
Node is intended to build and make simple requests to a device which hosts a restful api.
I am having issues in getting the config node which stores the credentials to actually keep them there.
The fields both go blank after I leave the config window.
I have used this https://nodered.org/docs/creating-nodes/credentials and have been looking at how the MQTT node stores its server properties.
For reference, everything else (Server, port) is saved but username/password is not.
I feel like I am missing something very simple but just can't work out what.
SOLVED:
Turns out I had missed "config" in the ID's for the input (IE: node-config-input-username/password). Only changed it for the label --__--
Watching this : https://www.coursera.org/lecture/developer-nodered/additional-node-configuration-options-aSFau
Made me realise my mistake.
