Would someone please share a flow with following requirements
- Open socket
- Open microphone (by click)
- Speak something
- Watson STT transcribes
- display interm results
- display final result with confidence score
- Close microphone (by click)
Thank you
Thank you
Well, it is for sure close to Christmas but still, this is a place where you can get advice and help on stuff you (try to) make yourself. Like building a flow and you are almost there, just need the final help
To me, as you put your requirements, it sounds more like you should hire a consultant. Or better & cheaper, begin your own journey with Node-RED. A lot of guidelines and other documents are available for exactly that purpose
Well you could start by playing with the dashboard ui microphone node - node-red-node-ui-microphone (node) - Node-RED
It can use the built in browser STT and a couple of modes of stop start
(It can also send segments you could forward to watson but that is somewhat more complex)
