Hi Everyone,
We currently make our own NR nodes by making use of a subflow to node converter. This enables us to use NR subflows as NR nodes in a more scalable way.
We have an issue with moving the credentials over to be available on the node, without needing to external input from the user. Currently, I just tried to pass the credentials file to the js file doing the node conversion. Please see this again.
module.exports = function(RED) {
const fs = require('fs');
const path = require("path");
const crypt = require("crypto-js");
const file = path.join(__dirname, "subflow.json");
const text = fs.readFileSync(file);
const flow = JSON.parse(text);
// Load credentials from flows_cred.json
const credentialsFile = path.join(__dirname, "flows_cred.json");
//RED.settings.userDir
const credentialsText = fs.readFileSync(credentialsFile);
const credentials = JSON.parse(credentialsText);
function getDecoder(encoding) {
var settings = RED.settings;
if (settings &&
settings.encodeSubflow &&
settings.encodeSubflow.methods) {
const methods = settings.encodeSubflow.methods;
const method = methods.find((x) => (x.name === encoding));
if (method) {
return method.decode;
if (encoding == "AES") {
return function (enc, key) {
var enc = crypt.AES.decrypt(enc, key)
var data = enc.toString(crypt.enc.Utf8);
return JSON.parse(data);
// no decoding
return null;
function convFlow(sf) {
const flow = sf.flow;
if (((typeof flow) === "object") &&
!Array.isArray(flow)) {
if (flow.hasOwnProperty("encoding") &&
flow.hasOwnProperty("flow")) {
const encoding = flow.encoding;
const body = flow.flow;
const decoder = getDecoder(encoding);
if (decoder) {
const key = process.env["NR_FLOW_DECODE_KEY"];
if (key && (key !== "")) {
try {
RED.log.info("deocde "+encoding+ " encoded flow");
const flowData = decoder(body, key);
sf.flow = flowData;
catch (e) {
throw new Error("flow decode error:"+e.toString());
else {
throw new Error("no flow decode key specified");
else {
throw new Error("no decoder found:" +encoding);
return sf;
RED.nodes.registerSubflow(convFlow(flow), credentials);
Credentials file:
"ecf3c5ed05011987": {},
"1777c59870e2d315": {
"user": "test",
"password": "test#5h7"
Unfortunately this is not doing the trick. Does anyone have an idea of how to best insert the credentials into the node automatically?
Kind regards,
Bartho
