Hello everyone.
I'm new to the forum and thank you in advance for your help and patience.
I would like to log some data from my heat pump.
Therefore I am trying to get the modbus connections running from my heat pump (waterkotte WPCU.C control, firmware C01.04.00) with an Moxa NP5110 to the RPI4.
The error log shows timed out statement but I am not able to figure ou t the route cause... reached the google search limits ![]()
Please have a look on the settings and the flow .. to find the problem. Grateful for any help.
flow:
"id": "b30d382e0e58daa2",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": "",
"env": []
"id": "f5019c7636823803",
"type": "inject",
"z": "b30d382e0e58daa2",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 110,
"y": 280,
"b0b177e512d8a1c0"
"id": "b0b177e512d8a1c0",
"type": "function",
"name": "function 1",
"func": "msg.payload = { \n 'fc': 4,\n 'unitid': 1,\n 'address': 433,\n 'quantity': 1\n};\n return msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 220,
"y": 360,
"f507c8b29d8ea302"
"id": "815ab9cf7062e8dc",
"type": "modbus-response",
"registerShowMax": 20,
"x": 630,
"y": 320,
"id": "3e6c578198c4a030",
"type": "debug",
"name": "debug 2",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 580,
"y": 260,
"id": "f507c8b29d8ea302",
"type": "modbus-flex-getter",
"showStatusActivities": true,
"showErrors": true,
"logIOActivities": false,
"server": "b910dbd8ba3e7f5e",
"useIOFile": false,
"ioFile": "",
"useIOForPayload": false,
"emptyMsgOnFail": false,
"keepMsgProperties": false,
"x": 400,
"y": 280,
"3e6c578198c4a030",
"815ab9cf7062e8dc"
"id": "b910dbd8ba3e7f5e",
"type": "modbus-client",
"name": "RS232-TCP-MOXA-NP5110",
"clienttype": "tcp",
"bufferCommands": false,
"stateLogEnabled": false,
"queueLogEnabled": false,
"failureLogEnabled": true,
"tcpHost": "192.168.100.18",
"tcpPort": "4001",
"tcpType": "DEFAULT",
"serialPort": "/dev/ttyUSB0",
"serialType": "RTU",
"serialBaudrate": "9600",
"serialDatabits": "8",
"serialStopbits": "1",
"serialParity": "none",
"serialConnectionDelay": "0",
"serialAsciiResponseStartDelimiter": "0x3A",
"unit_id": "1",
"commandDelay": "50",
"clientTimeout": "1000",
"reconnectOnTimeout": true,
"reconnectTimeout": "2000",
"parallelUnitIdsAllowed": true
Setting Moxa NP5110
Node Red debug log
pi@raspberrypi:~ $ DEBUG=contribModbus:write*,contribModbus:core:client,modbus-serial node-red -v
6 Nov 15:55:30 - [info]
Welcome to Node-RED
6 Nov 15:55:30 - [info] Node-RED version: v3.0.2
6 Nov 15:55:30 - [info] Node.js version: v16.18.0
6 Nov 15:55:30 - [info] Linux 5.15.74-v8+ arm64 LE
6 Nov 15:55:31 - [info] Loading palette nodes
6 Nov 15:55:34 - [info] Settings file : /home/pi/.node-red/settings.js
6 Nov 15:55:34 - [info] Context store : 'default' [module=memory]
6 Nov 15:55:34 - [info] User directory : /home/pi/.node-red
6 Nov 15:55:34 - [warn] Projects disabled : editorTheme.projects.enabled=false
6 Nov 15:55:34 - [info] Flows file : /home/pi/.node-red/flows.json
6 Nov 15:55:34 - [warn] Encrypted credentials not found
6 Nov 15:55:34 - [info] Server now running at http://127.0.0.1:1880/
6 Nov 15:55:34 - [info] Starting flows
contribModbus:core:client Client -> initialized +0ms
6 Nov 15:55:34 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init state after new TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:55:34 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> first fsm init in 500 ms TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:55:34 - [info] Started flows
contribModbus:core:client Client -> TCP port TCP@192.168.100.18:4001 default Unit-Id: 1 +513ms
modbus-serial TCP port: signal connect +0ms
6 Nov 15:55:35 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm connected after state init Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
debug3: send packet: type 98
modbus-serial {
modbus-serial action: 'send tcp port',
modbus-serial data: <Buffer 01 04 01 b1 00 01 60 11>,
modbus-serial buffer: <Buffer 00 01 00 00 00 06 01 04 01 b1 00 01>,
modbus-serial unitid: 1,
modbus-serial functionCode: 4,
modbus-serial transactionsId: 1
modbus-serial } +30s
modbus-serial modbusErrorHandling:Timed out +0ms
6 Nov 15:56:06 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm failed state after connected Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:06 - [warn] [modbus-flex-getter:f507c8b29d8ea302] Modbus Failure On State connected Get More About It By Logging
6 Nov 15:56:06 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm broken state after failed Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:06 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm reconnect state after broken Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:06 - [error] [modbus-flex-getter:f507c8b29d8ea302] Error: Timed out
at /home/pi/.node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:80:21
6 Nov 15:56:08 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init state after reconnecting TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:08 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init in 2000 ms TCP@192.168.100.18:4001 default Unit-Id: 1
contribModbus:core:client Client -> connection close sent TCP@192.168.100.18:4001 default Unit-Id: 1 +36s
contribModbus:core:client Client -> TCP port TCP@192.168.100.18:4001 default Unit-Id: 1 +0ms
modbus-serial TCP port: signal connect +5s
6 Nov 15:56:10 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm connected after state init Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
modbus-serial TCP port: signal close: false +3ms
contribModbus:core:client Client -> connection closed TCP@192.168.100.18:4001 default Unit-Id: 1 +9ms
modbus-serial {
modbus-serial } +11s
modbus-serial modbusErrorHandling:Timed out +16s
6 Nov 15:56:23 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm failed state after connected Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:23 - [warn] [modbus-flex-getter:f507c8b29d8ea302] Modbus Failure On State connected Get More About It By Logging
6 Nov 15:56:23 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm broken state after failed Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:23 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm reconnect state after broken Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:23 - [error] [modbus-flex-getter:f507c8b29d8ea302] Error: Timed out
6 Nov 15:56:25 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init state after reconnecting TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 15:56:25 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init in 2000 ms TCP@192.168.100.18:4001 default Unit-Id: 1
contribModbus:core:client Client -> connection close sent TCP@192.168.100.18:4001 default Unit-Id: 1 +16s
contribModbus:core:client Client -> TCP port TCP@192.168.100.18:4001 default Unit-Id: 1 +1ms
6 Nov 15:56:27 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm connected after state init Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
modbus-serial TCP port: signal close: false +5ms
contribModbus:core:client Client -> connection closed TCP@192.168.100.18:4001 default Unit-Id: 1 +10ms
modbus-serial {
modbus-serial } +13m
modbus-serial modbusErrorHandling:Timed out +13m
6 Nov 16:09:24 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm failed state after connected Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 16:09:24 - [warn] [modbus-flex-getter:f507c8b29d8ea302] Modbus Failure On State connected Get More About It By Logging
6 Nov 16:09:24 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm broken state after failed Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 16:09:24 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm reconnect state after broken Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 16:09:24 - [error] [modbus-flex-getter:f507c8b29d8ea302] Error: Timed out
6 Nov 16:09:26 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init state after reconnecting TCP@192.168.100.18:4001 default Unit-Id: 1
6 Nov 16:09:26 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm init in 2000 ms TCP@192.168.100.18:4001 default Unit-Id: 1
contribModbus:core:client Client -> connection close sent TCP@192.168.100.18:4001 default Unit-Id: 1 +13m
6 Nov 16:09:28 - [warn] [modbus-client:RS232-TCP-MOXA-NP5110] Client -> fsm connected after state init Get More About It By Logging TCP@192.168.100.18:4001 default Unit-Id: 1
contribModbus:core:client Client -> connection closed TCP@192.168.100.18:4001 default Unit-Id: 1 +14ms
