SVG node change image
Can someone help me how to change this image in the SVG node with a payload with the new link to the new image
Ingen tilgængelig billedbeskrivelse.
Synes godt om
Kommenter
Del
Hi @funhall,
Have you tried anything (via input msg) and did it fail with some error?
Bart
Thank you so much for the fast reply. I really appreciate it.
I have tried but dont think i did it right.
I am not sure how to send that msg. Is it from a function node and do I have to change the syntax in the SVG node?
Can you help with the flow please??. Here is the flow to import.
        "id": "11efafb081448151",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "c6f5630c59d25f58",
        "type": "ui_svg_graphics",
        "z": "11efafb081448151",
        "group": "f014eb03.a3c618",
        "order": 1,
        "width": "14",
        "height": "13",
        "svgString": "<svg xmlns=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" x=\"0\" y=\"0\" height=\"100%\" viewBox=\"0 0 400 100\" width=\"100%\" preserveAspectRatio=\"xMidYMid meet\"><rect id=\"svgEditorBackground\" x=\"0\" y=\"0\" width=\"100\" height=\"100\" style=\"fill:none;stroke:none\"/><defs id=\"svgEditorDefs\"><style type=\"text/css\">.svg_text_unselect{-moz-user-select: none;-webkit-user-select: none;-ms-user-select: none;}\n</style></defs>\n<!-- Add here your SVG shapes (circles, rectangles, ...) -->\n<!-- Or remove everything, if you want to paste an entire drawing (<svg...>...</svg>).-->\n<image x=\"-16.6269\" y=\"-65.2529\" width=\"396.714\" height=\"225.902\" id=\"e1_image\" preserveAspectRatio=\"xMidYMid meet\" xlink:href=\"https://funhall.dk/wp-content/uploads/2022/03/escape-rum-1-timer.jpg\" transform=\"matrix(1.09797 0 0 1 -11.6156 4.80591)\"/><text style=\"fill:white;font-size:40px;font-weight:bold;text-anchor:end;font-style:normal;font-family:&quot;Bookman Old Style&quot;\" x=\"378.779\" y=\"64.0543\" id=\"e3_texte\" xml:space=\"preserve\" class=\"svg_text_unselect\"> {{msg.payload}}</text><text style=\"fill:white;font-size:8px;font-weight:bold;text-anchor:end;font-style:normal;font-family:&quot;Bookman Old Style&quot;\" x=\"376.532\" y=\"124.14\" id=\"e2_texte\" xml:space=\"preserve\"> Penalty: {{msg.penalty}} min.</text><text style=\"fill:black;font-family:Arial;font-size:20px\" x=\"-8.666\" y=\"-40.668\" id=\"e1_texte\"/><text style=\"fill:white;font-family:Bookman Old Style;font-size:20px\" x=\"8.63731\" y=\"-26.9142\" id=\"e4_texte\">{{msg.hintHead}}</text><text style=\"fill:white;font-family:Bookman Old Style;font-size:8px\" x=\"8.41543\" y=\"-1.18169\" id=\"e5_texte\" xml:space=\"preserve\" textLength=\"61.85085449921053\" transform=\"matrix(0.75 0 0 0.75 7.64142 -1.60601)\"/><text style=\"fill:white;font-family:Bookman Old Style;font-size:8px\" x=\"10.5235\" y=\"-4.52878\" id=\"e6_texte\">{{msg.hint}}</text></svg>",
        "clickableShapes": [],
        "javascriptHandlers": [],
        "smilAnimations": [],
        "bindings": [],
        "showCoordinates": false,
        "autoFormatAfterEdit": false,
        "showBrowserErrors": false,
        "showBrowserEvents": false,
        "enableJsDebugging": false,
        "sendMsgWhenLoaded": false,
        "noClickWhenDblClick": false,
        "outputField": "payload",
        "editorUrl": "//drawsvg.org/drawsvg.html",
        "directory": "",
        "panning": "disabled",
        "zooming": "disabled",
        "panOnlyWhenZoomed": false,
        "doubleClickZoomEnabled": false,
        "mouseWheelZoomEnabled": false,
        "dblClickZoomPercentage": 150,
        "cssString": "div.ui-svg svg{\n    color: var(--nr-dashboard-widgetColor);\n    fill: currentColor !important;\n}\ndiv.ui-svg path {\n    fill: inherit;\n}",
        "name": "timer screen",
        "x": 610,
        "y": 300,
        "id": "b7b5192eb1b2d231",
        "type": "inject",
        "name": "Picture",
        "props": [
                "p": "image",
                "v": "https://funhall.dk/wp-content/uploads/2022/03/escape-rum-1-timer.jpg",
                "vt": "str"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "<svg xmlns=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" x=\"0\" y=\"0\" height=\"100%\" viewBox=\"0 0 400 100\" width=\"100%\" preserveAspectRatio=\"xMidYMid meet\"><rect id=\"svgEditorBackground\" x=\"0\" y=\"0\" width=\"100\" height=\"100\" style=\"fill:none;stroke:none\"/><defs id=\"svgEditorDefs\"><style type=\"text/css\">.svg_text_unselect{-moz-user-select: none;-webkit-user-select: none;-ms-user-select: none;} </style></defs> <!-- Add here your SVG shapes (circles, rectangles, ...) --> <!-- Or remove everything, if you want to paste an entire drawing (<svg...>...</svg>).--> timer screen / <image x=\"-16.6269\" y=\"-65.2529\" width=\"396.714\" height=\"225.902\" id=\"e1_image\" preserveAspectRatio=\"xMidYMid meet\" xlink:href=\"https://funhall.dk/wp-content/uploads/2022/03/escape-rum-1-timer.jpg\" transform=\"matrix(1.09797 0 0 1 -11.6156 4.80591)\"/><text style=\"fill:white;font-size:40px;font-weight:bold;text-anchor:end;font-style:normal;font-family:&quot;Bookman Old Style&quot;\" x=\"378.779\" y=\"64.0543\" id=\"e3_texte\" xml:space=\"preserve\" class=\"svg_text_unselect\"> {{msg.payload}}</text><text style=\"fill:white;font-size:8px;font-weight:bold;text-anchor:end;font-style:normal;font-family:&quot;Bookman Old Style&quot;\" x=\"376.532\" y=\"124.14\" id=\"e2_texte\" xml:space=\"preserve\"> Penalty: {{msg.penalty}} min.</text><text style=\"fill:black;font-family:Arial;font-size:20px\" x=\"-8.666\" y=\"-40.668\" id=\"e1_texte\"/><text style=\"fill:white;font-family:Bookman Old Style;font-size:20px\" x=\"8.63731\" y=\"-26.9142\" id=\"e4_texte\">{{msg.hintHead}}</text><text style=\"fill:white;font-family:Bookman Old Style;font-size:8px\" x=\"8.41543\" y=\"-1.18169\" id=\"e5_texte\" xml:space=\"preserve\" textLength=\"61.85085449921053\" transform=\"matrix(0.75 0 0 0.75 7.64142 -1.60601)\"/><text style=\"fill:white;font-family:Bookman Old Style;font-size:8px\" x=\"10.5235\" y=\"-4.52878\" id=\"e6_texte\">{{msg.hint}}</text></svg>",
        "x": 290,
        "y": 240,
                "c6f5630c59d25f58"
        "id": "1944fd142ff7fe72",
        "type": "inject",
        "name": "Test picture 1",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "https://funhall.dk/wp-content/uploads/2022/02/kaffe-frugtfad-3-scaled.jpg",
        "payloadType": "str",
        "x": 290,
        "y": 360,
                "c6f5630c59d25f58"
        "id": "f014eb03.a3c618",
        "type": "ui_group",
        "name": "Floorplan test",
        "tab": "80068970.6e2868",
        "order": 1,
        "disp": true,
        "width": "14",
        "collapse": false
        "id": "80068970.6e2868",
        "type": "ui_tab",
        "name": "SVG",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
Btw. i have other payload msg into the SVG node.
I now tryed this with no luck. Can you see what I am doing wrong.
I will have a look tonight. Now at work.
Thanks you so much......
I just figure it out.
But thanks anyway
