Hi.
Is it possible to change the backround colour dynamicly for a switch node depending the input?
/Niclas
Hi.
/Niclas
when yo say "switch node" are you talking about the node in the editor, or the ui-switch in the dashboard?
For the dashboard, take a look at this for things you can change: https://github.com/node-red/node-red-dashboard/blob/master/config-fields.md
Hi Im talking about the ui-switch. Can't se any property's to change bgcolor for this type in the link you posted.
Best regards Niclas
There is 3 elements in switch where background color can be changed.
All of them can be changed by overriding dashboard CSS using ui_template nodef
You can find basics from this thread š Customize dashboard CSS
Thanks.
Have read a lot about css and have tested to change background in chrome developer tools.
But I don't understand haw I change backroad in the ui template?
Can someone give me an example how I use a template node to change background color for a ui-switch
/Niclas
Try this
md-card.nr-dashboard-switch{
background-color:red !important;
Thanks. Will try this tomorrow.
/Niclas
