I have a switch node set as size 1 x 2 (Vertical)
That is ok.
Beside it I want to put a slider also sized 1 x 2 (vertical)
Yeah, but something isn't working. The slider is longer (taller) the switch.
That is ok.
yeah there are some limits... try 1x3
Yeah, had to upsize.
No problems.
(While here)
The name isn't being shown though.
[{"id":"fc61c4b5.e874b","type":"ui_slider","z":"26262ba1.62dcbc","name":"Brightness","label":"Brightness","tooltip":"","group":"c9a39d1d.9fa798","order":3,"width":"1","height":"2","passthru":true,"outs":"end","topic":"","min":0,"max":10,"step":1,"x":2480,"y":2210,"wires":[["ca9a7c11.32fa2"]]},{"id":"fa70d99a.b562","type":"ui_slider","z":"26262ba1.62dcbc","name":"Temp'","label":"Temp'","tooltip":"","group":"c9a39d1d.9fa798","order":4,"width":"1","height":"2","passthru":true,"outs":"end","topic":"","min":0,"max":"20","step":1,"x":2500,"y":2420,"wires":[["49781795.bbb75","712d12bd.1eba3c"]]},{"id":"c9a39d1d.9fa798","type":"ui_group","z":"","name":"BULB-2","tab":"aa487daa.33c1c","order":5,"disp":true,"width":"4","collapse":false},{"id":"aa487daa.33c1c","type":"ui_tab","z":"","name":"Real_World_Control","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
need to go to 1x4 for that as well.
Argh! Ok. I can live without it.
I may redesign it anyway so there is a colour slide behind the slider anyway.
For now it will suffice.
