Hello Guys
Once again I get some problems with the function-syntax. I would like to specify the options for the dropdown node with using variable. (See photo)
Can you give me a tip?
Thanks a lot!
The property name should not be in quotes to create the object. You can stringify the object or define as a string.
In the Line 3, it looks like you are trying to make an array of objects where the objects key is from global context.
This is a JavaScript thing - to use a variable value as a key name in an object, you must surround it with [ ]
e.g.
var keyName = "abc"
var value = 123
var newObj = { [keyName] : value }
// makes { "abc" : 123 }
Exactly what i need, thanks!
