Hey all!
I've searched the WWW for a solution but have yet to come upon something that is working or similar to my needs.
The project I am working on is a light controller GUI. The setup consists of ESP8266 devices which upon boot will register themselves to a Python HTTP Server hosted by Flask where they will be stored as objects in a dictionary. A 2nd server is running the node-red application serving as GUI.
Upon loading the homepage buttons are dynamically generated as so:
Upon clicking one of the buttons the UI control redirects to a 2nd tab hosting a control panel.
What I'd like to achieve is having the control panel loaded as an "embedded tab" just like the notification dialog appears in the middle of the screen display. I've attempted to "move" the control panel contents into a template node fed into the notification node which hasn't proven succesfull. The intended output should appear like so:
Any leads as to how I can achieve the before mentioned output will be greatly appreciated.
Have a great day!
