I would like to represent the following trend plots in a tabular format - meaning the dashboard displays two graphs besides each other instead of this representation:
create a second group and move the ones you want to that group
Or make the group wider and put them side by side in the one group.
Is this an entirely new question? If so then better to start a new thread as this one is marked as solved. When doing that please try and explain the problem better, I don't understand what you mean.
OK. I will do so. thanks for the suggestions, I agree the question is directly relevant to trends of the right corner plots but not the topic of the discussion.
To illustrate a bit more on the question I meant to ask about the possibility of coding two Y axis in one chart. For example, in the chart below - the top trends are the actual and predicted time-serieses and the bottom trend is their difference i.e., output prediction error - I want to see if it is possible to have the left side Y axis for the top trends and the right side Y axis for their difference.
No, I do not believe that is possible.
It is possible but takes a bit more than the chart note provides.
Explore the threads
