TCP In node read 2 values how to separate into 2 different global variable?
Without seeing what you did, it's hard to tell you what you might have done wrong.
Create a small flow demonstrating your problem and export it and attach to a reply. (add a debug node to your TCP node to capture some data. Then put that in an inject node in the sample flow)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
