TCP Node - message splitting question
I am sending 40,002 byte TCP packet from a microcontroller and reading it into Node-RED from the TCP node.
I'm reading the contents of the buffer using the debug node.
  1. The TCP packet seems to end up as two messages in Node-RED. Here you can see the sizes:
Is there any rhyme or reason as to why they are split or in what proportion?
  1. Is there a good way to detect disconnections? If I reset the microcontroller, it seems to show in the node status that one connection exists. Then when I restart the MCU it sometimes sees two connections, and sometimes seems to disconnect the first one. Any ideas why that may be?
From Google -
Ethernet traffic moves in units called frames. The maximum size of frames is called the Maximum Transmission Unit (MTU). When a network device gets a frame that is larger than its MTU, the data is either fragmented into smaller frames, or dropped. ... An Ethernet packet larger than 1500 bytes is called a jumbo frame .
Thanks, but how does this explain the message segmentation shown above?
Fair point, does it always split at the same sizes ?
It does seem to split into the same buffer sizes, when the same number of bytes are sent.
However if I send different numbers of bytes in the first place, the message splitting can be different.
I guess you can join the two payload together, but as to why it splits as it does I'm not sure.
Maybe there is a setting in NR that needs tweaking ?
You will need to wait for the smart people to help out :wink:
How do you have the tcp in node configured ? Which version of Node-RED ? Which OS are you running on ?
Hi, it's:
OS: Ubuntu 20.04.2 LTS
NodeRED version: 2.0.4
Here is how I have configured the TCP node:
Have you tried output single buffer ?
@hazymat Did you get anywhere with this ?
I tried setting output to single buffer, but it doesn't return anything. (Client connects okay, but no packets are shown on debug output)...
