Hello Andrei,
Thank you very much guys for helping me out.
I am just trying to get RGB values out of TCS34725 using I2C.
I am receiving data in an Array.
Sorry i have posted the right Flow (export)
[{"id":"466a72cc.9b04fc","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"d5900d0b.e3a8d","type":"mqtt-broker","z":"","name":"","broker":"www.mosquitto.org","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"869320ae.087a7","type":"ui_tab","z":"","name":"Garage","icon":"dashboard"},{"id":"5ab03ee9.8ea15","type":"ui_group","z":"","name":"Default","tab":"869320ae.087a7","disp":true,"width":"6","collapse":false},{"id":"b1960c96.51d89","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"c93fe99f.2e9378","type":"inject","z":"466a72cc.9b04fc","name":"","topic":"","payload":"","payloadType":"date","repeat":"2","crontab":"","once":false,"onceDelay":0.1,"x":230,"y":400,"wires":[["59890c25.0f4fe4"]]},{"id":"59890c25.0f4fe4","type":"i2c in","z":"466a72cc.9b04fc","name":"","address":"41","command":"0","count":"8","x":390,"y":400,"wires":[["8ba66948.c892e8","81d74fa1.9607f"]]},{"id":"f9148dc8.7669c","type":"debug","z":"466a72cc.9b04fc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":870,"y":400,"wires":[]},{"id":"8ba66948.c892e8","type":"function","z":"466a72cc.9b04fc","name":"","func":"var a = { payload: msg.payload[0] };\nvar b = { payload: msg.payload[1] };\nvar c = { payload: msg.payload[2] };\nvar d = { payload: msg.payload[3] };\nvar e = { payload: msg.payload[4] };\nvar f = { payload: msg.payload[5] };\nvar g = { payload: msg.payload[6] };\nvar h = { payload: msg.payload[7] };\nvar Clear= a+b;\nvar Red = c+d;\nvar Green= e+f;\nvar Blue = g+h;\nreturn Clear;","outputs":1,"noerr":0,"x":570,"y":400,"wires":[["f9148dc8.7669c"]]},{"id":"81d74fa1.9607f","type":"function","z":"466a72cc.9b04fc","name":"","func":"var a = { payload: msg.payload[0] };\nvar b = { payload: msg.payload[1] };\nvar Msg2 = { payload: msg.payload[2] };\nvar Msg3 = { payload: msg.payload[3] };\nvar Msg4 = { payload: msg.payload[4] };\nvar Msg5 = { payload: msg.payload[5] };\nvar Msg6 = { payload: msg.payload[6] };\nvar Msg7 = { payload: msg.payload[7] };\n\nreturn b;","outputs":1,"noerr":0,"x":570,"y":438,"wires":[[]]}]
