Telegram multiple msg.payload combined
Good day,
I am looking for a way to combine multiple msg.payload into one Telegram message.
The Telegram node get overwhelmed when it need to send to many replies, hence me wanting to combine the message in one reply..
See image attached.
Thank you for looking
Use a join node to join all the messages. there is an example in the node-red cook book.
https://cookbook.nodered.org/basic/join-streams
msg.payload = {
    "chatId": "234454653222",
    "topic": "06 AC_OUT_W",
    "type":"message",
    "content":"Power Usage = " + msg.payload + " W"};
Thanks, i think my formatting is wrong, i get chatID empty?
msg.payload = {
    "type":"message",
    "content":"Power Usage = " + msg.payload["06 AC_OUT_W"] + " W"};
The name of the topic becomes the payloads property.
Best to give the topic (instead of 206 AC_OUT_W" powerOut") a better name then you could use msg.payload.powerOut
my apologies, I am still battling here.
my 2 functions nodes are as follows:
msg.payload = {
    "chatId": "3333333333",
    "topic": "battvolt",
    "type":"message",
    "content":"Battery Voltage = " + msg.payload + " V"};
msg.payload = {
    "chatId": "44444433",
    "topic": "powerin",
    "type":"message",
    "content":"Eskom AC in = " + msg.payload + " V"};
My output from debug:
2
Result in no message to Telegram
I simplified my flow to only 2 nodes now just to try and make sense of it all. not good
1
i do mix the information like this
var satDisplayName  = msg.payload[0].satDisplayName;
var serverTime      = msg.payload[0].serverTime;
var freq            = msg.payload[0].freq;
var mode            = msg.payload[0].mode;
msg.payload = {chatId : 12345id , type : 'message', content :
"Satellit: " +"*" +satDisplayName +"*" +"\n" +"\n"
+mode +"@" +freq
+"\n" +"\n"
+serverTime
// activate markdown
//msg.payload.options = {disable_web_page_preview : true, parse_mode :"Markdown"};
Thank you for the reply, i dont understand
if you have a normal output like this
i just collect the Information i need with the var at the beginn.
and in the second part i put the var togehter to get a nice output in Telegram include to have important stuff in bold.
Join you values before the function then in a new function create the payload for telegram. You will only need one function node.
Reference you values like this in the function
Post your flow and i will edit for an example if you wish.
Thank you
[{"id":"2649c9fd.20f3b6","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"d77650ce.8d502","type":"change","z":"2649c9fd.20f3b6","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"powerin","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":280,"wires":[["6c71c520.8520bc"]]},{"id":"c1efedfc.ede68","type":"change","z":"2649c9fd.20f3b6","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"battvolt","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":240,"wires":[["2266906a.dbe5b"]]},{"id":"2266906a.dbe5b","type":"function","z":"2649c9fd.20f3b6","name":"Battery Voltage","func":"msg.payload = {\n    \"chatId\": \"xxxxx\", \n    \"type\":\"message\", \n    \"content\":\"Battery Voltage = \" + msg.payload + \" V\"};\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":360,"y":240,"wires":[["497bbc0f.902114"]]},{"id":"6c71c520.8520bc","type":"function","z":"2649c9fd.20f3b6","name":"AC in","func":"msg.payload = {\n    \"chatId\": \"xxxxx\", \n    \"type\":\"message\", \n    \"content\":\"Eskom AC in = \" + msg.payload + \" V\"};\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":350,"y":280,"wires":[["497bbc0f.902114"]]},{"id":"497bbc0f.902114","type":"join","z":"2649c9fd.20f3b6","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":590,"y":260,"wires":[["79c47aba.225df4"]]},{"id":"79c47aba.225df4","type":"telegram sender","z":"2649c9fd.20f3b6","name":"","bot":"","haserroroutput":false,"outputs":1,"x":850,"y":260,"wires":[[]]}]
Here is an example combined into one message. Not sure of telegrams formatting the newline may work.
[{"id":"8d31813f.e1cea","type":"inject","z":"2649c9fd.20f3b6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"36","payloadType":"num","x":100,"y":160,"wires":[["c1efedfc.ede68"]]},{"id":"c1efedfc.ede68","type":"change","z":"2649c9fd.20f3b6","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"battvolt","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":240,"wires":[["497bbc0f.902114"]]},{"id":"497bbc0f.902114","type":"join","z":"2649c9fd.20f3b6","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":330,"y":260,"wires":[["5be85aec.4b4884"]]},{"id":"d77650ce.8d502","type":"change","z":"2649c9fd.20f3b6","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"powerin","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":280,"wires":[["497bbc0f.902114"]]},{"id":"5be85aec.4b4884","type":"function","z":"2649c9fd.20f3b6","name":"Battery Voltage","func":"msg.payload = {\n    \"chatId\": \"xxxxx\", \n    \"type\":\"message\", \n    \"content\":\"Battery Voltage = \" + msg.payload.battvolt + \" V\\n Eskom AC in = \" + msg.payload.powerin + \" W\"};\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":260,"wires":[["a2328cf5.d40268"]]},{"id":"756c8b3a.0b490c","type":"inject","z":"2649c9fd.20f3b6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1000","payloadType":"num","x":100,"y":360,"wires":[["d77650ce.8d502"]]},{"id":"a2328cf5.d40268","type":"debug","z":"2649c9fd.20f3b6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":760,"y":260,"wires":[]}]
Much appreciated. Worked like a charm. Thank you
