Hi, i want read temperature from my amazon echo.
I have echo (not dot) with internal temp sensor.
I want read this temp without other external sensor.
Is possible?
Any help?
Thanks to all
I don't have an echo to test with, but if you look in Alexa app does the temp show up somewhere ?
Have a look at node-red-contrib-alexa-remote2-applestrudel, with this you can query devices connected to Alexa, eg colour of a light etc - so it may be possible to get the temp from the echo.
since the echo dot 5, there is now also an additional speaker that has a temperature sensor. Unfortunately, there doesn't seem to be anything yet that can be used to read out this value. That would be really ideal for temperature-based control. I have an echo dot 5 in several rooms and could use it to monitor the temperatures in all rooms.
