Hello, I have a small problem. I built a flow with which data from a temperature sensor can be written to an InfluxDB and displayed in Grafana.
The payload that is passed from the functions note into the DB looks like this.
{"eui":"temp001","temperature":21.8,"humidity":"NULL","battery":3.371}
The Gauge Node (ui-gauge) from Node Red Dashboard does not accept the temperature value. Why? What am I doing wrong?
What gauge node, what dashboard?
At a guess I assume node-red-dashboard.
If so you have two options
move msg.payload.temperature to msg.payload.
or change the value format field to
{{msg.payload.temperature}}
Failing this please supply more info.
YEEES....
changing the value format field to {{msg.payload.temperature}} didn't work, but moving ( Change Node) msg.payload.temperature to msg.payload. Can you explain that to me. Thank you
Try spelling temperature correctly, and then mark the post with the correct solution/s
