I have install on some of my esp, those with DS18B20, Tasmota firmware. I try to send only temperature value to a gauge node, but it receiv all topic mesage, like:
{"Time":"2024-02-17T07:56:39","DS18B20":{"Id":"0417315443FF","Temperature":23.5},"TempUnit":"C"}
I am a totaly beginer with node red, I try diffrent things found on the net but did not succed. Could someone help me ?
You may get some benefit watching these essentials videos as a beginner.
You can also retrieve the path to any message property using the side bar debug.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
As to your issue, in the value format field you can enter the path to the property Temperature like so
Use a change node to copy the property
you want to msg.payload (before the gauge).
Tbh, this is really basic/beginner stuff but important knowledge to get pretty much anything out of Node-RED so here is some info for you to absorb...
Always get the correct path to a property in a message:
Great for beginners:
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
